Seems that BlinkStick integration doesn’t work anymore on my Home Assistant Supervised after I installed 2022.7 update… I haven’t done any changes to YAML files after 2022.7 Core update. Does anybody others BlinkStick integration user have problems with it? Could problem be that BlinkStick integration is uncompatible with updated Python version?
Please note: My BlinkStick is special, Digispark (ATtiny85) powered version… It’s creator calls it as FadeStick.
In my configuration.yaml has these lines:
light:
- platform: blinksticklight
serial: BS000000-1.5
Log has these entries:
Logger: homeassistant.components.light
Source: components/blinksticklight/light.py:62
Integration: Valo ([documentation](https://www.home-assistant.io/integrations/light), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+light%22))
First occurred: 14.38.02 (1 occurrences)
Last logged: 14.38.02
blinksticklight: Error on device update!
Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 446, in _async_add_entity await entity.async_device_update(warning=False) File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 702, in async_device_update await task File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run result = self.fn(*self.args, **self.kwargs) File "/usr/src/homeassistant/homeassistant/components/blinksticklight/light.py", line 62, in update rgb_color = self._stick.get_color() File "/usr/local/lib/python3.10/site-packages/blinkstick/blinkstick.py", line 482, in get_color if isinstance(get_color_func, collections.Callable): AttributeError: module 'collections' has no attribute 'Callable'
Logger: homeassistant.helpers.service
Source: helpers/service.py:130
First occurred: 14.38.31 (3 occurrences)
Last logged: 14.38.56
Unable to find referenced entities light.blinkstick or it is/they are currently not available
