i’m pretty new in Hass.io.
I tried to follow this instructions to change the icon and font color on state-change: click.
It works to change the icon on state, to create to choose the theme but it doesn’t work to change the theme when the battery is low.
Did i something wrong when i was installing custom_ui?
Regards,
justcasper
This is my configuration.yaml:
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: 51.282
longitude: 7.0382
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 0
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/Berlin
# Customization file
customize: !include customize.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Show the introduction message on startup.
introduction:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Discover some devices automatically
discovery:
# Sensors
sensor: !include sensor.yaml
# Text to speech
tts:
- platform: google
#custom ui
customizer:
custom_ui: local
frontend:
themes:
alert_yellow:
primary-text-color: '#FFC000'
paper-item-icon-color: '#FFC000'
alert_red:
primary-text-color: '#FF0000'
paper-item-icon-color: '#FF0000'
group: !include groups.yaml
script: !include scripts.yaml
This is my customize.yaml:
sensor.monstera_battery_level:
custom_ui_state_card: state-card-custom-ui
friendly_name: "Door Sensor Battery Level"
templates:
theme: >
if (state < 20) {
return 'alert_red';
} else if (state < 40) {
return 'alert_yellow';
And this is my sensor.yaml
sensors:
solar_angle:
friendly_name: "Sun angle"
unit_of_measurement: 'degrees'
value_template: "{{ state_attr('sun.sun', 'elevation') }}"
sunrise:
value_template: "{{ state_attr('sun.sun', 'next_rising') }}" # Weather prediction
- platform: yr
#Mi Flora
- platform: miflora
mac: 'xxx'
friendly_name: Monstera Deiliciosa
force_update: false
median: 3
monitored_conditions:
- moisture
- light
- temperature
- conductivity
- battery
sensors:
unit_of_measurement: '%'
value_template: '{{ 1|int }}'
icon_template: >
{% set battery_level = states.sensor.monstera_battery_level.state|default(0)|int %}
{% set battery_round = (battery_level / 10) |int * 10 %}
{% if battery_round >= 100 %}
mdi:battery
{% elif battery_round > 0 %}
mdi:battery-{{ battery_round }}
{% else %}
mdi:battery-alert
{% endif %}
