Problems with ESP32 and Ili9341
I want to use an ESP32 and ESPhome to transfer data from HA to an Ili9341.
However, the connection to HA no longer works when I integrate the display into the ESPhome.yaml.
This way the code works without error messages and the ESP connects without error messages in the LOG:
substitutions:
  friendly_name: Solarbank
esphome:
  friendly_name: ${friendly_name}
  min_version: 2024.6.0
  name_add_mac_suffix: false
  project:
    version: dev
esp32:
  board: esp32dev
  framework:
    type: arduino
spi:
 clk_pin: 18
 mosi_pin: 23
 miso_pin: 19
font:
  - file: "gfonts://Roboto"
    glyphs:
      ['&', '@', '!', ',', '.', '?', '"', '%', '(', ')', '+', '-', '_', ':', '°', '0',
       '1', '2', '3', '4', '5', '6', '7', '8', '9', 'A', 'B', 'C', 'D', 'E',
       'F', 'G', 'H', 'I', 'J', 'K', 'L', 'M', 'N', 'O', 'P', 'Q', 'R', 'S',
       'T', 'U', 'V', 'W', 'X', 'Y', 'Z', ' ', 'a', 'b', 'c', 'd', 'e', 'f',
       'g', 'h', 'i', 'j', 'k', 'l', 'm', 'n', 'o', 'p', 'q', 'r', 's', 't',
       'u', 'v', 'w', 'x', 'y', 'z','å', 'Ä', 'ä', 'Ö', 'ö', 'Ü', 'ü', '/']
    glyphs:
color:
  - id: my_red
    red: 100%
    green: 0%
    blue: 0%
  - id: my_green
    red: 0%
    green: 100%
    blue: 0%
  - id: my_blue
    red: 0%
    green: 0%
    blue: 100%
  - id: my_turkis
    red: 5%
    green: 50%
    blue: 80%
  - id: my_yellow
    red: 100%
    green: 100%
    blue: 0%
# Enable logging
logger:
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
- platform: esphome
# Allow provisioning Wi-Fi via serial
improv_serial:
wifi:
  # Set up a wifi access point
  ap: {}
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
dashboard_import:
  package_import_url: github://esphome/example-configs/esphome-web/esp32.yaml@main
  import_full_config: true
# Sets up Bluetooth LE (Only on ESP32) to allow the user
# to provision wifi credentials to the device.
esp32_improv:
  authorizer: none
# To have a "next url" for improv serial
web_server:
But if I now insert the minimal configuration for the display, I no longer get a connection and the following error message appears in the log.
substitutions:
esphome:
  project:
    version: dev
esp32:
  board: esp32dev
  framework:
    type: arduino
display:
  - platform: ili9xxx
    model: ili9341
    dc_pin: 27
    reset_pin: 5
    invert_colors: false
    show_test_card: true
spi:
 clk_pin: 18
 mosi_pin: 23
 miso_pin: 19
font:
    glyphs:
    glyphs:
color:
  - id: my_red
    red: 100%
    green: 0%
    blue: 0%
  - id: my_green
    red: 0%
    green: 100%
    blue: 0%
  - id: my_blue
    red: 0%
    green: 0%
    blue: 100%
  - id: my_turkis
    red: 5%
    green: 50%
    blue: 80%
  - id: my_yellow
    red: 100%
    green: 100%
    blue: 0%
# Enable logging
logger:
api:
ota:
- platform: esphome
improv_serial:
wifi:
  ap: {}
captive_portal:
dashboard_import:
esp32_improv:
  authorizer: none
web_server:
Uploading: [============================================================] 100% Done...
INFO Upload took 28.80 seconds, waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from 192.168.178.176 using esphome API
WARNING Can't connect to ESPHome API for esphome-web-5e1914 @ 192.168.178.176: Timeout while connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.178.176', port=6053))] (TimeoutAPIError)
INFO Trying to connect to esphome-web-5e1914 @ 192.168.178.176 in the background
Static texts, lines, etc. work on the display, but the connection is no longer established.
Does anyone have an idea how I can get this under control?
I would guess you are running out of RAM. Serial logs would show more.
