Problems with First Daikin A/C Automation
Hello, I am trying to create my first automation to turn on my Daikin A/C when the room temperature drops below 19°C and turn it off when it reaches 23°C, as long as I am at home and the time is not between 10:00 PM and 7:00 AM. However, I can’t get it to work—it simply doesn’t start. If I run it manually, it performs the task, but I don’t know where the error might be. Here is my YAML. Help would be welcome.
alias: Control A/C Daikin según temperatura y presencia
description: >-
  Enciende o apaga el A/C según la temperatura y si estás en casa, excepto entre
  las 22:00 y las 7:00
triggers:
  - entity_id: sensor.daikinap78427_climatecontrol_room_temperature
    below: 19
    trigger: numeric_state
    above: 23
conditions:
  - condition: state
    entity_id: person.marcos
    state: home
  - condition: time
    after: "07:00"
    before: "22:00"
actions:
  - choose:
      - conditions:
          - condition: numeric_state
            below: 19
        sequence:
          - target:
              device_id: ed48c3255d7ae1be660885baf9007626
              hvac_mode: heat_cool
            action: climate.set_hvac_mode
          - data:
              message: >-
                El aire acondicionado se ha ENCENDIDO porque la temperatura bajó
                de 19°C.
            action: notify.mobile_app_iphone_de_marcos
      - conditions:
            above: 23
        sequence:
          - target:
            action: climate.turn_off
            data: {}
          - data:
              message: >-
                El aire acondicionado se ha APAGADO porque la temperatura
                alcanzó los 23°C.
mode: single
when you were testing it, what was the temperature? already bellow 19?
it won’t trigger again once it goes bellow 19, i.e. 17 or lower
so if i’m not mistaken, you have 2 triggers: for bellow 19 and above 23 and both of those conditions are never meet at the same time, because they just can’t be.
try changing it for test purposes only to 1 trigger, the one easier to reach to test faster, i’m guessing the 23C one and is if it triggers.
if it works, split the automation into two automations.
did you check the condition of you being home actually works? in the logs
also: did you check the Traces, Trace Timeline?
