Problems with frontend after upgrade to 0.21.0
I am having an issue with trying to load HA from chrome. i just get the logo and the spinning circle which changes color. the only way i can get it to load is by pressing [shift]+[F5]. when i go to the developer / about section, it doesn’t update any of the errors. i have to ssh into my raspberry pi3 and view the logs that way.
Here is an error i am getting frequently:
16-06-07 22:19:31 homeassistant.components.http: 127.0.0.1 - - [07/Jun/2016 22:19:31] “GET /api/stream?api_password=*******&restrict=state_changed,component_loaded,service_registered HTTP/1.0” 200 16529 149.629621
16-06-07 22:19:31 homeassistant.components.http: Traceback (most recent call last):
File “/var/opt/homeassistant/deps/eventlet/wsgi.py”, line 506, in handle_one_response
write(b’'.join(towrite))
File “/var/opt/homeassistant/deps/eventlet/wsgi.py”, line 453, in write
wfile.flush()
File “/usr/lib/python3.4/socket.py”, line 391, in write
return self._sock.send(b)
File “/var/opt/homeassistant/deps/eventlet/greenio/base.py”, line 379, in send
return self._send_loop(self.fd.send, data, flags)
File “/var/opt/homeassistant/deps/eventlet/greenio/base.py”, line 366, in _send_loop
return send_method(data, *args)
BrokenPipeError: [Errno 32] Broken pipe
OS: rapbian jessie
automations seem to work, but frontend is not behaving properly…
more errors:
16-06-07 22:39:40 homeassistant.components.http: 127.0.0.1 - - [07/Jun/2016 22:39:40] “GET /api/error_log HTTP/1.0” 200 8308 0.006886
16-06-07 22:39:41 homeassistant.components.http: Traceback (most recent call last):
File “/var/opt/homeassistant/deps/eventlet/wsgi.py”, line 501, in handle_one_response
data = data.encode(‘ascii’)
UnicodeEncodeError: ‘ascii’ codec can’t encode character ‘\xb0’ in position 7227: ordinal not in range(128)
Both are known. The broken pipe is fine as the rest of the log will actually show that it is handled properly.
The error log is a known issue and mentioned in the release notes.
Same here but I am not even getting the logo, I just get “Unable to connect”. even if I reboot the pi with putty :frowning:
Have u tried pressing [shift]+F5 to refresh your browser? If so, does the page load then? What browser are you using. I find that the issue is when I use chrome but internet explorer and safari seem to be ok.
