ok perhaps ive had too much festive Christmas wine over the last week but I am new to Home Assistant and installing this via your Hass.io image files for the Raspberry Pi. Basically I have downloaded the version for the Pi 4 and Pi 3 (both 32-bit and 64-bit) and the file downloads and extracts on my Mac. I then use BalenaEtcher to burn the IMG file to the SD card and it comes back stating the IMG file downloaded is corrupt. I tried downloading again and no luck at all. I then downloaded via my Windows Surface Pro and again if comes back with a file corruption error in BalenaEtcher. The IMG file was extracted and is showing as 2.147,483,648 in size. When downloading using my Mac the file automatically extracts to this size. For Windows I used 7Zip to extract and both are showing the same extracted file size.
Trust me I am not a numpty and I am used to burning IMG files to SD cards although I am currently sitting here thinking I must be!!
Are your versions I am trying to download are corrupt?
Just redownloaded and tried your suggestion as the file is showing as ‘hassos_rpi4-3.7.img.gz’ and is 182,442,027 bytes in size. Note: On the Mac it automatically extracts to the larger IMG file size of 2.15 GB’s so I used my Windows Surface Pro. Burning hassos_rpi4-3.7.img.gz and comes back with File Corrupt in BalenaEtcher.
Maybe there is a issue with your broadband connection that is corrupting the files - I have seen this before. Can you download the files via another method and try that ?
I’m currently facing the same issue. I tried with both ElenaBatcher and dd on Mac. Batcher tell me flash was successful but Mac gives me an error that it can not detect the filesystem.
After a while i wanted to start again with home-assistant. But it seems the error is still the same. After flashing with Etcher (latest version) the sd card looks the same with these 8 partitions. Anything i’m doing wrong? Hass.io image is 4.16
I have same problem: download the image file and flash it to SD card using balenaEtcher renders the card unreadable. Tried the same thing using Raspberry Pi Imager and with same result. Getting frustrated. OS= BigSur 11.1
Hi did exactly the same.
Even bought a new SD card with 64GB
If I try to open img file, it says its corrupt…
I ve also tried the 32Bit file w/o success
When inserting the card into the Win PC, only one 32MB partition incl. hasso is shown.
In the computer administration there is only this 32MB partition
