I have searched in all topics but nothing found. The image is self-explicative. There is a problem with the order on layers in all the UI, not only in dasboards, not only in theese specific screenshoots: they are all behind other graphics, not for the last menu without other things around (obviously). The problem is not ony aesthetic but even functional. It happen with all themes, even restarting host at changing themes. It happens from a couple of updates ago. How to resolve?
My system:
RPi 3 B+
Hass.io
Home Assistant OS 5.12
Home Assistant Core-2021.3.4
Supervisor 2021.03.6
In logs nothing of strange appear… at least for me.
Thanks in advance for any reply.
It’s most likely your browser, what browser are you using?
I mainly use Google Chrome, but I have tried all browsers and, on all of them, it behaves the same.
Did you find any resolution on this?
I get it all the time only in chrome from any computer.
I have tried changing to the default theme, I tried disabling chrome addons.
All themes, and all chrome seems to cause it, even on tablets.
Seems that nobody has a solution…
I think that it could be easy to solve… but i don’t have a fully knowledge on all Home Assistant system… The problem depend on frontend part, I guess.
I also have an issue in chrome with the lovelace editor sometimes glitching out and portions of it disappearing. Maybe if you and I compare what addons we have installed we can correlate a culprit.
EDIT: I may have solved it, I found an addon I had installed called “kibibit Frosted Cards”.
Removing it and clearing my cache and so far I have not seen the glitches. I will update if they reappear.
@MrKuenning Wonderfull! You found the solution!!!
As you wrote, I disinstalled the same HACS’s plug-in, the “Kibibit Frosted Cards”, cleared the Chrome cache and all is working again!! This worked for me too!!! I cleared the Home Assistant app cache even on my Android phone and it worked again too!
Then I suppose that was this plug-in to cause this behaviour. Now, I’m testing if reappear… and I wrote an issue to the programmer to fix it… seems that the problem is knowed to the programmer since 25/11/2020 (look at this: 3 Button Menus · Issue #5 · Kibibit/kb-frosted-cards · GitHub).
Thank you again MrKuenning!
