Hi!
I had a previous setup using raspberry pi 3, docker and rflink which worked without problems. After a harddrive crash I setup everything again from scratch using my old configuration files (same hardware) but I get the following error message.
File "/usr/src/homeassistant/homeassistant/components/rflink/__init__.py", line 234, in connect
transport, protocol = await connection
File "/usr/local/lib/python3.8/asyncio/coroutines.py", line 124, in coro
res = func(*args, **kw)
File "/usr/local/lib/python3.8/site-packages/serial_asyncio/__init__.py", line 410, in create_serial_connection
ser = serial.serial_for_url(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/serial/__init__.py", line 88, in serial_for_url
instance.open()
File "/usr/local/lib/python3.8/site-packages/serial/serialposix.py", line 268, in open
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
serial.serialutil.SerialException: [Errno 2] could not open port /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0: [Errno 2] No such file or directory: '/dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0'
2020-09-06 16:29:55 WARNING (MainThread) [homeassistant.components.rflink] disconnected from Rflink, reconnecting
2020-09-06 16:29:55 INFO (MainThread) [homeassistant.components.rflink] Initiating Rflink connection
2020-09-06 16:29:55 ERROR (MainThread) [homeassistant.components.rflink] Error connecting to Rflink, reconnecting in 10
I suppose
could not open port /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0: [Errno 2] No such file or directory: ‘/dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0’ is of importance here.
I use docker-compose and here is my compose file.
version: '3'
services:
homeassistant:
container_name: home-assistant
image: homeassistant/home-assistant:stable
volumes:
- /home/homeassistant/.homeassistant:/config
- /data/homeassistant:/data/homeassistant
devices:
- /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0:/dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
- /dev/ttyUSB0:/dev/ttyUSB0
environment:
- TZ=Norway/Oslo
restart: always
network_mode: host
ports:
- "8123:8123"
Does anyone have any ideas on what to try next? The path: /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port do exist on my Pi
