I got an issue with the Risco alarm integration, since a few months it is more offline then available. I want to use it with the cloud integration because i want to know if the system is armed or not and i want to arm or disarm it. For example i have an automation that triggers the garden lights when we get home so we wont walk in the dark. but now the lights go on and off 20 or 30times a night…
In my log i find the following data:
Logger: homeassistant.components.risco
Source: helpers/update_coordinator.py:229
Integration: Risco ([documentation](https://www.home-assistant.io/integrations/risco), [issues](https://github.com/home-assistant/core/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+risco%22))
First occurred: 27 augustus 2023 om 18:25:24 (92 occurrences)
Last logged: 11:53:59
Error fetching risco data: {'result': 72, 'validationErrors': None, 'errorText': None, 'errorTextCodeID': None, 'status': 200, 'response': None}
And:
Source: components/risco/__init__.py:95
First occurred: 27 augustus 2023 om 18:24:20 (1 occurrences)
Last logged: 27 augustus 2023 om 18:24:20
Error in Risco library: 'NoneType' object is not subscriptable
I have removed and reinstalled the plugin, configured local to see if it helps, created a separate user for the system… But nothing works?
On my dashboard it says Not available. and sometimes but not for long available.
Hope that someone knows what is wrong…
