Problems with setup of emoncms local
Hi. I am having problems with the setup of my emoncms in HA.
I use an emonTX with an emonESP for the WiFi connection to my HA.
If i enter the emoncms i see all Feeds:
When i hoover over the Feeds, i can see the Feed-ID’s which i use in my sensors.yaml in HA.
On Node emonTX-1, i see Feed-ID 1 to 5, and on emonXT-1 Feed-ID’s 6 to 11.
So i used the Feed-ID’s 6 - 11 in my config in sensord.yaml:
# emonCMS local
- platform: emoncms
  url: 192.168.178.235/emoncms
  api_key: 3948b4d779bd39xxxxxxxxxx571a3c80
  scan_interval: 30
  include_only_feed_id:
    - 6
    - 7
    - 8
    - 9
    - 10
    - 11
But i can’t get any entities in HA.
After the restart after changing the config, i get this in my log:
Logger: homeassistant.components.emoncms.sensor
Source: components/emoncms/sensor.py:257
Integration: emoncms (documentation, issues)
First occurred: 7:16:53 PM (1 occurrences)
Last logged: 7:16:53 PM
Invalid URL '192.168.178.235/emoncms/feed/list.json': No schema supplied. Perhaps you meant http://192.168.178.235/emoncms/feed/list.json?
But when i enter this URL (http://192.168.178.235/emoncms/feed/list.json) in my browser i’l get this output:
[{"id":"1","userid":"1","name":"Power","datatype":"1","tag":"Node emonTX-1","public":"0","size":"33144472","engine":"5","processList":"","unit":"W","value":493,"time":1635441525,"start_time":1551875850,"interval":10},{"id":"2","userid":"1","name":"Solar","datatype":"1","tag":"Node emonTX-1","public":"0","size":"33144452","engine":"5","processList":"","unit":"W","value":4,"time":1635441525,"start_time":1551875900,"interval":10},{"id":"3","userid":"1","name":"EV","datatype":"1","tag":"Node emonTX-1","public":"0","size":"32974752","engine":"5","processList":"","unit":"W","time":1634312800,"value":-254,"start_time":1551875960,"interval":10},{"id":"4","userid":"1","name":"Netspanning","datatype":"1","tag":"Node emonTX-1","public":"0","size":"33143144","engine":"5","processList":"","unit":"V","value":223.877129,"time":1635441525,"start_time":1551879170,"interval":10},{"id":"5","userid":"1","name":"Temp-meterkast","datatype":"1","tag":"Node emonTX-1","public":"0","size":"5523872","engine":"5","processList":"","unit":"\u00b0C","value":20.2,"time":1635441525,"start_time":1551879180,"interval":60},{"id":"6","userid":"1","name":"import_kWh","datatype":"1","tag":"emonTX-1","public":"0","size":"170232","engine":"5","processList":"","unit":"kWh","time":1635441525,"value":162.28950263538,"start_time":1634311450,"interval":10},{"id":"7","userid":"1","name":"Solar_kWh","datatype":"1","tag":"emonTX-1","public":"0","size":"169980","engine":"5","processList":"","unit":"kWh","time":1635441525,"value":79.83894604834,"start_time":1634312080,"interval":10},{"id":"8","userid":"1","name":"EV","datatype":"1","tag":"emonTX-1","public":"0","size":"169720","engine":"5","processList":"","unit":"","value":2,"time":1635441525,"start_time":1634312730,"interval":10},{"id":"9","userid":"1","name":"EV_kWh","datatype":"1","tag":"emonTX-1","public":"0","size":"169720","engine":"5","processList":"","unit":"kWh","time":1635441525,"value":7.6389594475318,"start_time":1634312730,"interval":10},{"id":"10","userid":"1","name":"use","datatype":"1","tag":"emonTX-1","public":"0","size":"164388","engine":"5","processList":"","unit":"W","value":4,"time":1635441525,"start_time":1634326060,"interval":10},{"id":"11","userid":"1","name":"use_kwh","datatype":"1","tag":"emonTX-1","public":"0","size":"164388","engine":"5","processList":"","unit":"kWh","time":1635441525,"value":75.37842816504,"start_time":1634326060,"interval":10},{"id":"12","userid":"1","name":"solar","datatype":"1","tag":"emonTX-1","public":"0","size":"16","engine":"5","processList":"","unit":"W","time":null,"value":null,"start_time":0,"interval":10},{"id":"13","userid":"1","name":"solar_kwh","datatype":"1","tag":"emonTX-1","public":"0","size":"16","engine":"5","processList":"","unit":"kWh","time":null,"value":null,"start_time":0,"interval":10},{"id":"14","userid":"1","name":"import","datatype":"1","tag":"emonTX-1","public":"0","size":"16","engine":"5","processList":"","unit":"W","time":null,"value":null,"start_time":0,"interval":10},{"id":"15","userid":"1","name":"import_kwh","datatype":"1","tag":"emonTX-1","public":"0","size":"16","engine":"5","processList":"","unit":"kWh","time":null,"value":null,"start_time":0,"interval":10},{"id":"16","userid":"1","name":"use","datatype":"1","tag":"emonesp","public":"0","size":"16","engine":"5","processList":"","unit":"W","time":null,"value":null,"start_time":0,"interval":10},{"id":"17","userid":"1","name":"use_kwh","datatype":"1","tag":"emonesp","public":"0","size":"16","engine":"5","processList":"","unit":"kWh","time":null,"value":null,"start_time":0,"interval":10},{"id":"18","userid":"1","name":"solar","datatype":"1","tag":"emonesp","public":"0","size":"16","engine":"5","processList":"","unit":"W","time":null,"value":null,"start_time":0,"interval":10},{"id":"19","userid":"1","name":"solar_kwh","datatype":"1","tag":"emonesp","public":"0","size":"16","engine":"5","processList":"","unit":"kWh","time":null,"value":null,"start_time":0,"interval":10},{"id":"20","userid":"1","name":"import","datatype":"1","tag":"emonesp","public":"0","size":"16","engine":"5","processList":"","unit":"W","time":null,"value":null,"start_time":0,"interval":10},{"id":"21","userid":"1","name":"import_kwh","datatype":"1","tag":"emonesp","public":"0","size":"16","engine":"5","processList":"","unit":"kWh","time":null,"value":null,"start_time":0,"interval":10},{"id":"22","userid":"1","name":"solar_kWh","datatype":"1","tag":"emonTX-1","public":"0","size":"16","engine":"5","processList":"","unit":"kWh","time":null,"value":null,"start_time":0,"interval":30},{"id":"23","userid":"1","name":"tx1ct1","datatype":"1","tag":"emonesp","public":"","size":"0","engine":"5","unit":"","time":null,"value":null,"start_time":0,"interval":30}]
So I do not understand why i get this error in the log…
And i do not know the term ‘No schema supplied.’ What schema should i supply, and where…
And the URL’s in the log ‘http://192.168.178.235/emoncms/feed/list.json’ are both the same???
Any help is much appreciated. Kind regards, Bert
The value for URL is wrong.
It needs to include http:// … so http://192.168.178.235/emoncms
@scriven33,
Thank you for pointing me on my mistake. It feels so st*pid… I have looked it over and over again but did not see it.
I had emoncms already earlier configured and working but due to an error with my the Energy integration i switched back to an older snapshot and started again.
Thanks again.
