I have a problem with an integration via HACS. I installed Variables+History via HACS, and since a few days I get the following message after every restart. I don’t know what to do with it and how to fix it!! I’ve already removed it once from HACS but then my variables don’t work anymore.
See pictures:
Like many integrations over the past couple years, it has been moved from manual YAML configuration to configuration via the UI.
You do not need to remove the integration from HACS… if you have already done so, add it back to HACS, make sure it appears in your Integrations page, and the restart HA. If your lucky, your existing entities will be automatically imported. Then you will need to remove (or at least comment out) the manual configuration from your configuration.yaml file (or wherever you put it if you use a split configuration). Restart HA again.
