Problems Yaml file nested if statem
the keypad text made with matrix keypad does control 2 lights 1 red en one yellow if keypad is “1234” red light toggles and if keypad is “4567” yellow light(geellicht) supposed to toggle on or off. But code wont validate and i get this message:
ERROR Error while reading config: Invalid YAML syntax:
mapping values are not allowed here
and it refers to second if under first else. Can anyone help here im not that good in yaml
text_sensor:
    lambda: |-
      return {"------"};
    on_value:
      then:
         - if:
            condition:
                # pincode codes for buitenalarm
              - text_sensor.state:
                state: '1234'
            then:
                - switch.turn_on: buzzer1
                - delay: 1s
                - switch.turn_off: buzzer1
                - delay: 1s
                - delay: 1s
                - light.toggle: roodlicht
            else:
              - if:
                  condition
                      state: '45678'
                  then:
                     - delay: 1s
                     - delay: 1s
                     - delay: 1s
                     - light.toggle: geellicht
                  else:
                    - if:
                        condition:
                           state: '------'
                  then:
                  else:
                    - repeat:
                       count: 3
                       then:
                          - delay: 500ms
                          - delay: 500ms
Only half your config is formatted correctly for the forum.
how come ? how i format config ?
It’s late at night here so brain is at half function - but is the indentation of this section correct? Remember with yaml indentation es everything when it comes to syntax.
…and everywhere on your code where you have
then:
    - dosomething
should be:
then:
  - dosomething
