Processor fan not showing up
Hi everybody,
while at the time of writing this is not critical, for the future i’d like to use the attached cooling fan on my RPi 4 (HASS installation in a DIN enclosure in the breaker box) to come on as required. I have created a little board which can read out PWM signals through a GPIO pin and control the fan accordingly, this was tested under Raspberry OS on this machine and it worked without problems. Here’s the circuit layout:
I then installed both the pi_gpio and pi_gpio_pwm integrations through HACS and no errors are reported by the system.
As per the installation manual provided, I added the following to configuration.yaml:
fan:
  - platform: rpi_gpio_pwm
    fans:
      - name: RPI Cooling Fan
        pin: 4
        unique_id: procfan
The configuration test shows no errors, still there’s nothin showing up, neither on the dashboard nor in the entities list. Any ideas?
Core 2025.1.4
Supervisor 2024.12.3
Operating System 14.1
Frontend 20250109.2
running on RPi 4
Sorry, cannot add another image to the post above. Here’s the HACS integration list:
