Proxmox 9.1, does HAOS work?
Did a fresh install of proxmox and overlooked the fact that it was only couple of days old v9.1.
Tried to use the proxmox helper installer script for HAOS, but it said 9.1 wasn’t supported.
Guess what I’m asking is, can I install HAOS manually on 9.1 proxmox or is it unsupported and I should wait?
Why not reinstall/downgrade proxmox to v9.0?
Please read Proxmox VE 9.1 Release - Now Available! (read TL;DR first) · community-scripts/ProxmoxVE · Discussion #9278 · GitHub. Maybe you can use the patch provided in the last post.
For anyone else looking:
“I have confirmed that the Homeassistant OS install script works fine on 9.1.1 (had to manually edit it to remove the version range check)” was in the link Marco sent.
Following the link; On the bottom (as of writing this) is the “fake-patch” that helps install the HAOS, while they still investigate changes in VM’s.
FYI: in the meantime the community script does work flawlessly on Proxmox 9.1.4 (fresh installed), executed in just a few minutes.
