Proxmox-addon partly doesn't work after HA core-update
after updating HA core to 2025.05.02 my proxmox integration doesn’t work partly.
That means, I have to proxmox devices enabled. One with username, password and pam as realm. After disablbling and enabling the integration entries, it’s working now.
The other device was configuerd with user: HomeAssistant, Tokenname and token. REALM is pve.
I had a look at the log:
Logger: homeassistant.config_entries
Source: config_entries.py:1098
First occurred: 11:05:28 AM (1 occurrence)
Last logged: 11:05:28 AM
Error migrating entry 192.168.178.140:8006 for proxmoxve
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1098, in async_migrate
    result = await component.async_migrate_entry(hass, self)
  File "/config/custom_components/proxmoxve/__init__.py", line 372, in async_migrate_entry
    dev_reg.async_update_device(
        device_id=device.id,
    ...<7 lines>...
  File "/usr/src/homeassistant/homeassistant/helpers/device_registry.py", line 1117, in async_update_device
    added_identifiers = new_values["identifiers"] = self._validate_identifiers(
        device_id, new_identifiers, False
  File "/usr/src/homeassistant/homeassistant/helpers/device_registry.py", line 1231, in _validate_identifiers
    raise DeviceIdentifierCollisionError(identifiers, existing_device)
homeassistant.helpers.device_registry.DeviceIdentifierCollisionError: Identifiers {('proxmoxve', '01JQHGHT9WFNFY19KFGY8B05QN_DISK_pve_nvme.144d-533733444e583158323434353533-53414d53554e47204d5a564c3435313248424c552d3030425457-00000001')} already registered with DeviceEntry(area_id=None, config_entries={'01JQHGHT9WFNFY19KFGY8B05QN'}, config_entries_subentries={'01JQHGHT9WFNFY19KFGY8B05QN': {None}}, configuration_url='https://192.168.178.140:8006/#v1:0:=node/pve::2::::::', connections=set(), created_at=datetime.datetime(2025, 5, 20, 11, 3, 34, 162020, tzinfo=datetime.timezone.utc), disabled_by=None, entry_type=<DeviceEntryType.SERVICE: 'service'>, hw_version=None, id='2084c107cee90cc829c000d028b0be26', identifiers={('proxmoxve', '01JQHGHT9WFNFY19KFGY8B05QN_DISK_pve_nvme.144d-533733444e583158323434353533-53414d53554e47204d5a564c3435313248424c552d3030425457-00000001')}, labels=set(), manufacturer='unknown', model='NVME SAMSUNG MZVL4512HBLU-00BTW ', model_id=None, modified_at=datetime.datetime(2025, 5, 20, 11, 3, 38, 57551, tzinfo=datetime.timezone.utc), name_by_user=None, name='Disk pve: SAMSUNG MZVL4512HBLU-00BTW', primary_config_entry='01JQHGHT9WFNFY19KFGY8B05QN', serial_number='S73DNX1X244553', suggested_area=None, sw_version=None, via_device_id='03e290375c03868c5651717c52d3901c', is_new=False, _cache={'json_repr': b'{"area_id":null,"configuration_url":"https://192.168.178.140:8006/#v1:0:=node/pve::2::::::","config_entries":["01JQHGHT9WFNFY19KFGY8B05QN"],"config_entries_subentries":{"01JQHGHT9WFNFY19KFGY8B05QN":[null]},"connections":[],"created_at":1747739014.16202,"disabled_by":null,"entry_type":"service","hw_version":null,"id":"2084c107cee90cc829c000d028b0be26","identifiers":[["proxmoxve","01JQHGHT9WFNFY19KFGY8B05QN_DISK_pve_nvme.144d-533733444e583158323434353533-53414d53554e47204d5a564c3435313248424c552d3030425457-00000001"]],"labels":[],"manufacturer":"unknown","model":"NVME SAMSUNG MZVL4512HBLU-00BTW ","model_id":null,"modified_at":1747739018.057551,"name_by_user":null,"name":"Disk pve: SAMSUNG MZVL4512HBLU-00BTW","primary_config_entry":"01JQHGHT9WFNFY19KFGY8B05QN","serial_number":"S73DNX1X244553","sw_version":null,"via_device_id":"03e290375c03868c5651717c52d3901c"}'})
I have no idea what this means.
I have the same issue. Anyone has an idea how to solve it yet?
Thanks,
Patrick
The core integration or the one from HACS ?
I’m using HACS and downgraded the version from 4.0.2 to 3.5.2 which resolved the issue for now
Anyone have a fix for this yet? I’m having the same issue with 4.0.2 ever since I upgraded to Home Assistant Core 2025.7.1
Hello together,
same issue here. No idea how to solve it.
same issue here, but from 2025.9.x
Any solution?
I’ve just installed this addon for the first time, as I’m part-way through migrating my HASS VM to proxmox.
Installing the current version 4.0.2 gave me a bunch of entities I can’t do anything with, and no devices. I downgraded to 3.5.2 as suggested earlier in the thread, and I now get a working set of devices with entities in them.
I’m considering trying to update to 4.0.2 again, but I haven’t get, as it’s working.
Connection is using a dedicated user in PVE with full admin permissions. I received a permissions warning when I tried to use PVEAdmin role.
PVE server is latest 9.0.11.
