Hi Team
The question:
-using a NUC with proxmox, should I use hassio image or a ‘Ubuntu image with docker with Hassio ?
Just got hold of a NUC and would like to install proxmox and then an image with HA.
This image, should that be a HASSIO image directly ? or should I install Ubuntu, with docker, and then add Hassio ? Guess the end result would be the same (one just ubuntu based, and the other …. What ever HASSIO is build on).
But somehow I feel with the ubuntu setup, I can use the Docker setup for other stuff. But could I do the same with the HASSIO image ?
Option is also, that since I will be using proxmox, just to add another image, with docker for the rest of the container…
What do you recommend ?
Regards Jørn
