Proxmox lxc Bluetooth
Hi Guys,
I try to get bleutooth working but i get the following message
Code:
root@homeassistant:~# service bluetooth status
* bluetooth.service - Bluetooth service
     Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
     Active: failed (Result: exit-code) since Sun 2023-02-19 01:55:36 UTC; 46s ago
       Docs: man:bluetoothd(8)
    Process: 887 ExecStart=/usr/libexec/bluetooth/bluetoothd (code=exited, status=1/FAILURE)
   Main PID: 887 (code=exited, status=1/FAILURE)
     Status: "Starting up"
        CPU: 13ms
Feb 19 01:55:36 homeassistant systemd[1]: Starting Bluetooth service...
Feb 19 01:55:36 homeassistant bluetoothd[887]: Bluetooth daemon 5.55
Feb 19 01:55:36 homeassistant systemd[1]: Started Bluetooth service.
Feb 19 01:55:36 homeassistant bluetoothd[887]: src/adapter.c:adapter_init() Failed to access management interface
Feb 19 01:55:36 homeassistant bluetoothd[887]: src/main.c:main() Adapter handling initialization failed
Feb 19 01:55:36 homeassistant systemd[1]: bluetooth.service: Main process exited, code=exited, status=1/FAILURE
Feb 19 01:55:36 homeassistant systemd[1]: bluetooth.service: Failed with result 'exit-code'.
actually my usb controller is passed trough
Code:
root@homeassistant:~# ls -l /dev/bus/usb/001/003
crw-rw-rw- 1 root root 189, 2 Feb 18 23:11 /dev/bus/usb/001/003
then i did this
Code:
root@homeassistant:~# lsmod | grep bluetooth
bluetooth             679936  6 btrtl,btintel,btbcm,bnep,btusb
ecdh_generic           16384  1 bluetooth
followed by this
Code:
hciconfig
Can't open HCI socket.: Address family not supported by protocol
it seems to me the system does not know that the adapter is the bluetooth adapter
did you find a solution? i have exactly the same issue
