Proxmox with an ubuntu VM running HA and Deconz in Docker - can't see each other?
I have been shifting across all my containers from Synology NAS Docker to a Proxmox with an ubuntu VM. I have several containers running incl HA and Deconz but they don’t want to see each other. I have them both on the host network, but HA does not detect via Discovery the deconz container (which is working fine - has connected to all the zigbee devices in the house). Can anyone push in the right direction as to why it can’t be seen? Must be something to do with firewalls between Proxmox and Ubuntu?
EDIT I should point out HA can see via Discovery my Ecobee and Hue bridge no worries, but they are not running under docker of course…
I’m not sure if deconz supports auto discovery. Did you try adding the deconz integration manually?
You were right @Burningstone, I thought it was discovery enabled. all good now. Thanks
