I have homeassistant running on kubernetes and in front i have istio ingress with TLS passthrough, this causes an issue that the source ips of the clients connecting to homeassistant get lost, the source ip that shows in homeassistant is from the istio ingress gateway.
I know that if don’t set tls passtrough and configure tls termination on the istio gateway then it would use the x-forwarded-for and homeassistant would see the real ip of the clients, but this is not an option for my services, i have tls configured on end services, so on the ingress gateway i do tls passtrough, and with this the only way would be having proxy protocol support on homeassistant.
Is there any plan to implement proxy protocol on homeassistant?
Thank you.
