PS4 component - HA and PS4 on separate VLANs/broadcast domains
Wanted to see if someone could confirm this, do Home Assistant and the PS4 need to be on the same broadcast domain for this component to work? https://www.home-assistant.io/components/ps4/
I’m assuming yes as it keeps saying no PS4 found. If that’s the case are there any other options here? I have a “media” network where my PSx’s live along with other media player (FireTV, DVD player, AMP, etc). I have another IoT network which is where my HA instance lives. The Onkyo component works across VLANs as I can specify the IP address and allow it in the firewall.
Is there any way to make the PS4 work with a manual configuration by knowing it’s IP address? Or some other way to make it work?
Thanks so much!
Dan
Bump, any thoughts?
Specifying ip address is now possible.
@Ktnrg45 - killer! When you say now do you mean when 0.92 releases?
