PSKReporter Monitor brings real-time amateur radio digital mode propagation data from PSKReporter.info into Home Assistant. Track FT8, FT4, WSPR, and other digital modes with live statistics, per-band activity, and feed health monitoring.
Features
Personal Callsign Monitoring - Track spots for your specific callsign (RX, TX, or both)
Global Propagation Monitor - PSKReporter-wide statistics without requiring a callsign
Per-Band Activity - Monitor propagation on 160m through 6m bands
Feed Health Monitoring - Real-time MQTT connection and data flow status
Distance & SNR Filtering - Focus on DX or local propagation
Low-Resource Mode - Count-only option for memory-constrained devices
Two Deployment Options - Native HACS integration or Docker/MQTT bridge
Monitor Modes
Mode
Callsign Required
Use Case
Personal
Yes
Track whoβs hearing your signal, monitor your band conditions
Global
No
Network-wide propagation, great for non-hams
Sensors
Category
Sensors
Activity
Total Spots, Unique Stations, Spots/min, Last Spot Time
Propagation
Most Active Band, Most Active Mode, Max Distance, Avg SNR
Three releases since the original post β hereβs whatβs new.
v2.4.0 β Band Filter & DXCC Wanted List
Band Filter β Limit processing to specific bands (e.g., 20m, 40m, 6m). Multi-select in HACS options or SPOT_BAND_FILTER env var for Docker.
DXCC/Band Wanted List β Define DXCC/band combos youβre chasing (e.g., 339:20m,150:40m). When a matching spot arrives, pskr-ha-bridge fires a pskr_wanted_spot event (HACS) or publishes MQTT sensors (Docker). This is a detector β all spots still flow normally; wanted matches trigger additional alerts. Thanks to Graham VK3GA for suggesting this feature.
50 new per-band sensors covering 10 amateur bands β each band gets unique countries, spot count, SNR average, best SNR, and farthest station. Plus new aggregate sensors:
DX Ratio β percentage of spots from outside your own DXCC entity
Propagation Score β composite 0β100 score based on band activity, unique countries, and distance
Farthest Station β callsign, distance, and bearing of the most distant spot
The integration now provides 78 sensors + 2 binary sensors in personal mode.
