Publish json for Victron dbus driver
hello i want to send my PV Data from my growatt direktly to my VenusOS.
At the moment ich use ESP Home on a Growatt Stick to collect the Data. and send it via MQTT. in the second part i send the values via Node Red on my VenusOS via Nod.
Now i want to try to send the data directly. my yaml works fine without the send part.
substitutions:
  devicename: "esphome-growatt-01"
  upper_devicename: "ESPHome Growatt 01"
esphome:
  platform: ESP8266
  board: esp07s
# Enable logging
logger:
  baud_rate: 0
# Enable Home Assistant API
#api:
#  password: "01234"
mqtt:
  broker: 192.168.1.12
  port: 1884
  username: Nils
  password: !secret mqtt_password
ota:
  password: "01234"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "GGrowatt"
    password: "oLjULFvNXq1l"
# Enable Web server
web_server:
  port: 80
captive_portal:
 #time:
 #   - platform: homeassistant
 #     id: homeassistant_time
output:
  # Blue Led
    - id: light_bl
      platform: gpio
      pin: 16
  # Green Led
    - id: light_gr
      platform: gpio
      pin: 0
  # Red Led
    - id: light_rd
      platform: gpio
      pin: 2
uart:
    tx_pin: 1
    rx_pin: 3
    baud_rate: 115200
modbus:
    uart_id: mod_bus
modbus_controller:
    - id: growatt
  # the Modbus device addr
      address: 0x1
      modbus_id: modbus1
      update_interval: 10s
      setup_priority: -10
    - platform: modbus_controller
      address: 5
      register_type: "read"
      unit_of_measurement: W
      device_class: power
      icon: mdi:flash
      value_type: U_DWORD
      accuracy_decimals: 1
      filters:
      - multiply: 0.1
      name: "${devicename} DcVoltage"
      address: 3
      unit_of_measurement: V
      device_class: voltage
      icon: mdi:flash
      value_type: U_WORD
      filters:
      - multiply: 0.1
      name: "${devicename} DcInputCurrent"
      address: 4
      unit_of_measurement: A
      device_class: current
      icon: mdi:flash
      value_type: U_WORD
      filters:
      - multiply: 0.1
      name: "${devicename} AcFrequency"
      address: 37
      unit_of_measurement: Hz
      icon: mdi:flash
      value_type: U_WORD
      filters:
      - multiply: 0.01
      name: "${devicename} AcVoltage"
      address: 38
      icon: mdi:flash
      value_type: U_WORD
      filters:
      - multiply: 0.1
      name: "${devicename} AcOutputCurrent"
      address: 39
      icon: mdi:flash
      value_type: U_WORD
      filters:
      - multiply: 0.1
      address: 40
      device_class: power
      icon: mdi:flash
      value_type: U_DWORD
      filters:
      - multiply: 0.1
      name: "${devicename} EnergyToday"
      address: 53
      unit_of_measurement: kWh
      device_class: energy
      icon: mdi:flash
      value_type: U_DWORD
      filters:
      - multiply: 0.1
      name: "${devicename} EnergyTotal"
      address: 55
      state_class: total_increasing
      icon: mdi:flash
      value_type: U_DWORD
      accuracy_decimals: 2
      filters:
      - multiply: 0.1
      name: "${devicename} Temperature"
      address: 93
      unit_of_measurement: C
      device_class: temperature
      icon: mdi:thermometer
      value_type: U_WORD
      filters:
      - multiply: 0.1
    - platform: mqtt_subscribe
      topic: the/topic
      on_value:
        then:
          - lambda: |-
              esphome::modbus_controller::ModbusController *controller = id(growatt);
              uint16_t reg = 3; // Register: Max output active power (in %)
              float value = id(mqtttest).state;
              uint16_t register_value = static_cast<uint16_t>(value);
              modbus_controller::ModbusCommandItem setOutputPower_command = modbus_controller::ModbusCommandItem::create_write_single_command(controller, reg, register_value);
              controller->queue_command(setOutputPower_command);
    #- platform: mqtt_subscribe
    #  name: "mqtttest"
    #  id: mqtttest
    #  topic: the/topic
    #  on_value:
    #    lambda: |-
    #      id(poweroutput).state;
#neu test power factor 02/2023
number:
      name: "${devicename} Max Output Active Power"
      address: 3
      value_type: U_WORD
      min_value: 0
      max_value: 100
      entity_category: config
      step: 1
the mqtt message should have this json
msg.payload = {
    "pv": {
        "power": msg.payload["P"],
        "voltage": msg.payload["V"],
        "current": msg.payload["I"],
        "energy_forward": msg.payload["W"],
        "L1": {
return msg;
this is my first try
      address: 40
      device_class: power
      icon: mdi:flash
      value_type: U_DWORD
      filters:
      - multiply: 0.1
	   on_value:
        - mqtt.publish_json:
            topic: "Growatt/mic2000/meters"
            payload: |-
              return {"pv": {
				power": id(pv_power).state,
				"voltage": id(pv_voltage).state,
				"current": id(pv_current).state,
				"energy_forward": id(pv_energy_forward).state,
				"L1": {
					"power": id(pv_power).state,
