Has anyone used the Pulcro hardware?
It comes with Home Assistant installed, similarly to HA Green.
Any good or bad experiences with this hardware?
I haven’t used it, but I assume you’re talking about this:
It looks like a pretty standard miniPC. It does mention “Home Assistant 15” which I assume is referring to the HAOS version (since Home Assistant core uses numbering like 2026.04.01). That’s kind of old, so you’re going to have to do a bunch of upgrades right off the bat (unless their web site just isn’t up to date).
I just restored from a new backup file.
I believe the first update it mentioned was 18.1.
They do mention that they try to keep the OS installations fresh. But there is always a chance that an update is needed from the time it was created and shipped, to the time you set it up.
So far everything has gone smoothly.
I was just wondering how many others have tried the system.
It seemed as easy to set up as the HA Green.
