Thanks Tom… It was a long time ago since I was in math class
All working fine now
Thank you all for your help…
Are you sure your calculation is correct? What is your time-interval?
You are supposed calculate like this: sensor_value * 0.1 * (time_interval in seconds / 3600)
Or shorter: sensor_value * (time_interval in seconds / 36000)
Also, this is (only) valid when using the derivative-sensor, I have no idea what the output means of the statistics sensor.
As bouwew says you can use the derivative platform
Did you get this to work properly?
I can’t see that mine is working at all.
What am I missing?
# - platform: derivative
# source: sensor.rfxmeter_count_2e_counter_value
# name: RFXMeter change per hour
# round: 1
# unit_time: h # the resulting "unit_of_measurement" will be °C/h if the sensor.temperate has set °C as it's unit
# time_window: "00:01:00" # we look at the change over the last half hour
- platform: statistics
entity_id: sensor.rfxmeter_count_2e_counter_value
precision: 3
max_age:
minutes: 15
sensors:
rfxmeter:
friendly_name: "RFXMeter"
value_template: "{{ state_attr('sensor.rfxmeter_count_2e_counter_value','change_rate') |float * 0.1 * 3600 | round(0)}} Watt"
