I managed to merge the code as mentioned. This uses a touch switch module on a ESPHOME ESP-01 node to control a remote HASS light.
A click toggles the light while holding the switch brightens or dims it. To reverse operation (e.g. if it is dimming and you need it brighten) then release the hold down and go straight to hold down again.
I hope it is helpful.
esphome:
platform: ESP8266
board: esp01_1m
substitutions:
devicename: light-remote-switch # name of this node
upper_devicename: "Light and Switch" # English Readable name for the node
short_devicename: "LightSwitch" # Short form English readable name
hass_light: "light.study_ceiling" # HASS entity name of the HASS light to be controlled
address_ip: X.Y.Z.A
address_subnet: Y.Y.Y.Y
address_gateway: X.Y.Z.B
wifi:
ssid: !secret wifi_ssid
domain: !secret wifi_domain
reboot_timeout: 5min
manual_ip:
static_ip: $address_ip
gateway: $address_gateway
subnet: $address_subnet
logger:
api:
ota:
globals:
- id: bool_dim_or_bright #false = dim, true = brighten
type: bool
restore_value: no
initial_value: 'false'
switch:
# This is to restart the ESPHome device remotely
- platform: restart
name: ${upper_devicename} - Restart
- platform: wifi_signal
name: ${upper_devicename} - WiFi
update_interval: 60s
- platform: homeassistant #a local sensor to hold the HASS light brightness
entity_id: $hass_light
attribute: brightness
binary_sensor:
- platform: homeassistant # a local binary sensor to hold the HASS light on / off status
- platform: gpio
pin: # Note: This must be true or the ESP-01 will not boot is using a touch switch module (which must be set to be active low)
number: 0
inverted: TRUE
mode: INPUT_PULLUP
filters:
- delayed_on: 50ms
- delayed_off: 50ms
on_click:
then:
- if:
binary_sensor.is_off: controlled_light_on_hass # if light is off, turn it on
then:
- homeassistant.service:
service: light.turn_on
else: # else it is on so turn it off
service: light.turn_off
on_press:
then:
- if:
lambda: |-
return id(bool_dim_or_bright);
# When above condition evaluates to true - brighter function else dimmer
then:
- delay: 0.5s
- while:
binary_sensor.is_on: touch_switch
then:
brightness_step: "5"
# transition: "1"
- delay: 0.05s
- lambda: |-
id(bool_dim_or_bright) = (false);
else:
- delay: 0.5s
- while:
and:
- binary_sensor.is_on: touch_switch
# This is to set the minimum value so that touch sensor only allows pre-set minimum
- sensor.in_range:
above: 10
then:
brightness_step: "-5"
# transition: "1"
- delay: 0.05s
- lambda: |-
id(bool_dim_or_bright) = (true);
