Hi there, (sorry for my english, i’m not sure to be very understandable)
I just install Home Assistant on a RPi this weekend in my house with some LoraTap light switch. All is ok and it’s really great except in the dinning room.
I put a switch light instead of the telerupteur, I have 3 push buttons. With the HA panel it’s work fine, but for the 3 buttons it’s not good.
When I push a button the light turns on, it’s ok. But when I release the button the light turn off, and I need it stays on until the next push. I try to make automatisation in HA and change my cable to have the switch and the telerupteur together, but nothing work fine.
Is it possible to configure this in Home Assistant ?
If someone had a solution it would be great
yes, this is it. but I don’t find how configure the switch to stay “on” when I push a button, like when I turn it on with HA. I see it possible with a fibaro FGS-212 and Jeedom.
so I was thniking maybe with this switch and HA it’s possible too
Did you flash it with Tasmota, or are you using the Tuya integration ? If flashed with Tasmota it is just setting the correct switchmode in the Tasmota console.
a last question, I have take a quick look about flashing my switch and I’ve found several ways, Tasmota, ESPurna, ESPeasy and ESPhome.
The ESP Home integration in HA look like the most simple, but I don’t know if there are the same capability than Tasmota ?
