I try to set up Pushbullet but I can’t get to work.
When I execute the script it see that it has been turned on, small notification message in the HA webgui.
But I don’t receive any notification in my phone were I have the Pushbullet app installed.
How can I fault trace this?
I receive following error in the log.
Apparently has I not used the account in a long time. How can I active it again?
2018-11-13 10:55:47 ERROR (SyncWorker_6) [homeassistant.components.notify.pushbullet] Notify failed: {"error":{"code":"invalid_request","type":"invalid_request","message":"Account has not been used for over a month.","cat":"(=xェx=)"},"error_code":"invalid_request"}
Last time I solved the problem and got Pushbullet to work.
But now last week it stopped to work again.
I tried to manually send a notification but it don’t work.
Pushbullet free account has a limit of 100 messages a month. You can try to send msg again and check your logs after it will show you an api error if this is the case. You can also login to your account to check.
Edit sorry just saw your error msg yep you have exceeded your msg limit, you either need to restrict the amount of notifications you send or use a paid account. Your account will reset at end of month.
