I love using the Pushetta notification system but every message is prepended with “Home Assistant”. So when I send a message like “Home Assistant has started”, I get a message “Home Assistant Home Assistant has started”. Can you add an option to remove this “Home Assistant” prefix?
The “Home Assistant” prefix you see is probably the default title. Try to set a title when you send the message.
You’re right, the prefix is almost removed if I set the title to “” on all my notifications. I say “almost” as the messages are now prefixed by a space (which I assume is the space between title and message). When you submit your next change, can you either 1. add an option to remove the title and space (preferred) or 2. do not display the space if title is blank?
Thanks, pushetta works great!
