PUT method for RESTful components
RESTful command appears to support put but other components, like the RESTful switch do not. I understand that I can probably get the same switch behavior with a command switch, but it seems like the RESTful switch method would be cleaner.
rest command, with put method support
Would be nice if you could test it and comment on the Pull request. Thanks.
Will be shipped with 0.47.
