Put parameter with Keyboard
Hi everybody,
I’ve got adjustables countdowns in my interface :
Capture
When it finish, I’ve got a notification with the message : “Minuteur 1 is finished !”
As I wish use it to cooking and as I’ve got few countdowns, I wanna put a variable name, and write it to keybord in place of “Minuteur 1”.
Does it possible ?
I hope to be clear…
Thank you !!
I’m not aware of a textbox where you can write down a text and use it further.
But if you have a certain amount of recurring times, you could pre-define it with an input_select?
https://home-assistant.io/components/input_select/
Huum… I should think about this solution…!
Thank you !
Can you share code for this countdown? Thanks.
Of course !!
For sensor :
    sensors:
      minuteur_1_time:
        friendly_name: 'Minuteur_1 : '
        value_template: '{{"%0.02d" | format(states("input_slider.minuteur_reglable_1") | int) }} minutes'
    sensors:
      minuteur_1_end:
        friendly_name: 'Finira à : '
        value_template: '{{ ((now().strftime("%s") | int + (states("input_slider.minuteur_reglable_1") | int) * 60) | timestamp_custom("%H:%M")) }}'
For input_slider :
  minuteur_reglable_2:
    icon: mdi:timer
    initial: 0
    min: 0
    max: 59
    step: 1
Input_boolean :
    initial: off
Automation :
- alias: 'Minuteur Réglable 1'
  initial_state: 'on'
  hide_entity: False
    - platform: state
      entity_id: input_boolean.minuteur_reglable_1
      to: 'on'
    - delay: '00:{{ "%0.02d" | format(states("input_slider.minuteur_reglable_1") | int) }}:00'
    - service: switch.turn_on
    - service: input_boolean.turn_off
    - service: notify.pushbullet
          message: "Le minuteur 1 est terminé !!"
          title: "Jarvis"
Thanks again. :slight_smile: Is it possible to make this work with hours not just minutes?
Yes, you just need to add an “Input Slider” for hours and to adapt sensor part !
