Put state of current active relay in the LCD on 1 spot
Dear people,
Can anyone help me to write a peace for my script , on how do I put the state of the current active relays (1 to 4) in the LCD on 1 spot, or off.
My idea was to put the current active value in a variable and set that state in the LCD:
With something like: it.printf(0, 0, id(Kraan_selector).state ? “:%s”);
I have a 4x20 i2c LCD and 4 relay’s from where only 1 can be active at the same time (garden sprinker valves).
For what I would like to do, is to put the state of the current relay on 1 spot on the display.
Right now every relay has 1 line, so it takes 4 lines. Good, but can be better!
Thanc you in Advance!!!
Here is my current working script:
esphome:
  platform: ESP32
  board: esp-wrover-kit
ethernet:
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO0_IN
  phy_addr: 1
  power_pin: GPIO16
# Enable logging
logger:
# Enable Home Assistant API
api:
web_server:
  port: 80
ota:
  password: "boeba tie boeb "
#I2C config
i2c:
  sda: 4
  scl: 2
  scan: True
###################Globals#########################
globals:
- id: zone_start_time
  type: int
  restore_value: no
  initial_value: '0'
- id: zone_run_time
  type: int
  restore_value: no
  initial_value: '0'
##################Lambda timer script##################
interval:
  - interval: 1s
    then:
      - if:
          condition:
            lambda: |-
              return id(zone_start_time) != 0;
          then:
          - lambda: |-
              id(zone_run_time) = id(homeassistant_time).now().timestamp - id(zone_start_time);
          - logger.log:
              format: "Zone run time %.1d"
              args: [ 'id(zone_run_time)' ]
          else:
          - lambda: |-
              id(zone_run_time) = 0;
###################Countdown timer################
      - if:
          condition:
            for:
              time: 20min
              condition:
              -  switch.is_on: KAS_RELAY_1
          then:
            - switch.turn_off: KAS_RELAY_1
      - if:
          condition:
            for:
              time: 20min
              condition:
              -  switch.is_on: KAS_RELAY_2
          then:
            - switch.turn_off: KAS_RELAY_2
      - if:
          condition:
            for:
              time: 20min
              condition:
              -  switch.is_on: KAS_RELAY_3
          then:
            - switch.turn_off: KAS_RELAY_3
      - if:
          condition:
            for:
              time: 20min
              condition:
                - switch.is_on: KAS_RELAY_4
          then:
            - switch.turn_off: KAS_RELAY_4
######################PCF HUBS####################
pcf8574:
  - id: 'pcf8575_1'
    address: 0x20
    pcf8575: False
  - id: 'pcf8575_2'
    address: 0x21
    pcf8575: False
  - id: 'pcf8575_3'
    address: 0x22
    pcf8575: False
###################pcf8575 Relay#################
switch:
  - platform: restart
  - platform: gpio
    interlock: [KAS_RELAY_2 ,KAS_RELAY_3, KAS_RELAY_4]
    pin:
      pcf8574: pcf8575_1
      number: 0
      mode: OUTPUT
      inverted: True
    on_turn_on:
        - switch.turn_on: KAS_LED_1_BLINK
        - lambda: |-
              id(zone_start_time) = id(homeassistant_time).now().timestamp;
    on_turn_off:
        - switch.turn_off: KAS_LED_1_BLINK
        - lambda: |-
  - platform: gpio
    interlock: [KAS_RELAY_1 ,KAS_RELAY_3, KAS_RELAY_4]
    pin:
      pcf8574: pcf8575_1
      number: 1
      mode: OUTPUT
      inverted: True
    on_turn_on:
        - switch.turn_on: KAS_LED_2_BLINK
        - lambda: |-
    on_turn_off:
        - switch.turn_off: KAS_LED_2_BLINK
        - lambda: |-
  - platform: gpio
    interlock: [KAS_RELAY_1 ,KAS_RELAY_2, KAS_RELAY_4]
    pin:
      pcf8574: pcf8575_1
      number: 2
      mode: OUTPUT
      inverted: True
    on_turn_on:
        - switch.turn_on: KAS_LED_3_BLINK
        - lambda: |-
    on_turn_off:
        - switch.turn_off: KAS_LED_3_BLINK
        - lambda: |-
  - platform: gpio
    interlock: [KAS_RELAY_1 ,KAS_RELAY_2, KAS_RELAY_3]
    pin:
      pcf8574: pcf8575_1
      number: 3
      mode: OUTPUT
      inverted: True
    on_turn_on:
        - switch.turn_on: KAS_LED_4_BLINK
        - lambda: |-
    on_turn_off:
        - switch.turn_off: KAS_LED_4_BLINK
        - lambda: |-
  - platform: gpio
    pin:
      pcf8574: pcf8575_1
      number: 4
      mode: OUTPUT
      inverted: True
    on_turn_on:
        - switch.turn_on: KAS_LED_5
    on_turn_off:
        - switch.turn_off: KAS_LED_5
  - platform: gpio
    pin:
      pcf8574: pcf8575_1
      number: 5
      mode: OUTPUT
      inverted: True
  - platform: gpio
    pin:
      pcf8574: pcf8575_1
      number: 6
      mode: OUTPUT
      inverted: True
  - platform: gpio
    pin:
      pcf8574: pcf8575_1
      number: 7
      mode: OUTPUT
      inverted: True
###################pcf8575 LED#################
  - platform: gpio
    pin:
      pcf8574: pcf8575_2
      number: 2
      mode: OUTPUT
      inverted: False
    optimistic: yes
    turn_on_action:
    - while:
        condition:
          lambda: 'return true;'
        then:
        - delay: 500ms
        - delay: 500ms
    turn_off_action:
  - platform: gpio
    pin:
      pcf8574: pcf8575_2
      number: 1
      mode: OUTPUT
      inverted: False
    optimistic: yes
    turn_on_action:
    - while:
        condition:
        then:
        - delay: 500ms
        - delay: 500ms
    turn_off_action:
  - platform: gpio
    pin:
      pcf8574: pcf8575_2
      number: 0
      mode: OUTPUT
      inverted: False
    optimistic: yes
    turn_on_action:
    - while:
        condition:
        then:
        - delay: 500ms
        - delay: 500ms
    turn_off_action:
  - platform: gpio
    pin:
      pcf8574: pcf8575_2
      number: 3
      mode: OUTPUT
      inverted: False
    optimistic: yes
    turn_on_action:
    - while:
        condition:
        then:
        - delay: 500ms
        - delay: 500ms
    turn_off_action:
  - platform: gpio
    pin:
      pcf8574: pcf8575_2
      number: 4
      mode: OUTPUT
      inverted: true
###################pcf8575 KNOP#################
binary_sensor:
  - platform: gpio
    pin:
      pcf8574: pcf8575_3
      number: 3
      mode: INPUT
      inverted: True
    on_press:
      then:
        - switch.toggle: KAS_RELAY_1
  - platform: gpio
    pin:
      pcf8574: pcf8575_3
      number: 0
      mode: INPUT
      inverted: True
    on_press:
      then:
        - switch.toggle: KAS_RELAY_2
  - platform: gpio
    pin:
      pcf8574: pcf8575_3
      number: 1
      mode: INPUT
      inverted: True
    on_press:
      then:
        - switch.toggle: KAS_RELAY_3
  - platform: gpio
    pin:
      pcf8574: pcf8575_3
      number: 2
      mode: INPUT
      inverted: True
    on_press:
      then:
        - switch.toggle: KAS_RELAY_4
  - platform: gpio
    pin:
      pcf8574: pcf8575_3
      number: 4
      mode: INPUT
      inverted: True
    on_press:
      then:
        - switch.toggle: KAS_RELAY_5
###################Omgevings sensors##############
##Baro/Druk/Vocht##
  - platform: bme280
    address: 0x76
    update_interval: 60s
    temperature:
      oversampling: 16x
    pressure:
    humidity:
##Licht sensor##
  - platform: tsl2561
    address: 0x39
####################LCD##########################
display:
  - platform: lcd_pcf8574
    dimensions: 20x4
    address: 0x27
    lambda: |-
      it.printf(0, 0, "Kas  "":%s", id( KAS_RELAY_1 ).state ? "ON" : "OFF");
      it.printf(0, 1, "Krn.1"":%s", id( KAS_RELAY_2 ).state ? "ON" : "OFF");
      it.printf(0, 2, "Krn.2"":%s", id( KAS_RELAY_3 ).state ? "ON" : "OFF");
      it.printf(0, 3, "Krn.3"":%s", id( KAS_RELAY_4 ).state ? "ON" : "OFF");
      it.printf(10, 0, "Tmp"":%.1f""C", id(Temp).state);
      it.printf(10, 1, "Hum"":%.1f""%", id(Hum).state);
time:
  - platform: homeassistant
