I’m new to hass and I could manage most of the configuration. I configured my pv panels sensor using MQTT protocol. Here are the settings my configuration.yml:
It works well and I can see correct values for both power (sensor.pv_power) and energy (sensor.pv_energy). However, I realized that both power energy are still giving positive value after sunset. It seems that the last recorded value is kept constant overnight:
Thanks for your suggestion. I looked at the documentation but I don’t really know what to do. Could you give me a bit of guidance on how to use availability template in my case, given this configuration?
I also realized that the calculated exported energy “export_energy” also yields a weird behavior. It basically jumped this morning from 0 to 5,7kWh when my pv system started producing, which is quite unrealistic. Could it also be related with the missing availability template in each sensor?
I see that the last MQTT message posted by my pv sensor for power is indeed [1643040924,17,"W"]. I guess I need to setup a logic that sets power to 0 after sunset or something like that?
What are you using to measure these values?
I basically have 3 sensors providing power measurements (W) that I read from my flukso MQTT broker. I have an energy integration setup for each of these sensors:
Imported Power from the grid “import_power” sensor. I then use the energy integration to calculate imported energy to “sensor.import_energy”. Config:
Grid Power Import/Export messages (XXXX/PUB/CH0/PI and XXXX/PUB/CH0/PE topics) are send to my Flukso Broker using a LoWi3 device that is connected to the P1 port of my grid smart meter (Siconia T211).
The PV generation (Wh) is measured by a pulse counter that is connected to my Flukso meter. PV power is available on the Flukso broker in the /sensor/XXXXX/gauge message that I use in HA configuration. There is also the PV energy (in Wh) available on /sensor/XXXXX/gauge topic on the Flukso broker, but I’m not using it at the moment (the value of the gauge topic correspond to the total energy provided by my PV system for years and I didn’t know how to deal with that in HA).
