PWM fan + BMP280 not possible on Wemos D1 Mini with ESPHOME?
I’m currently building a Wemos d1 mini with a PWM(4 pin) fan(5v noctua) and a BMP280 sensor. The idea is that the fan starts when the temperature gets over a certain amount. Currently I can get readings from the BMP280 when its connected. And I can control the fan when that is connected. But when they are both connected I lose the signal to the Wemos? My setup is a s below:
esphome:
  friendly_name: ps4-fan
esp8266:
  board: d1_mini_lite
# Enable logging
logger:
  level: DEBUG
# Enable Home Assistant API
api:
  encryption:
    key: "CMDazGqOZhiITVk1EqDP1SwL3SIDcu7IIcMFgHRkOfM="
ota:
  password: "1ffeb0eeccdfc8aba11a70397d475df4"
wifi:
  ssid: "something"
  password: "something"
  ap:
    ssid: "Ps4-Fan Fallback Hotspot"
    password: ""
captive_portal:
i2c:
  scl: D1
  sda: D2
  scan: True
  - platform: pulse_counter
    pin: D4
    name: PWM Fan RPM
    unit_of_measurement: 'RPM'
    filters:
      - multiply: 0.5
    count_mode:
      rising_edge: INCREMENT
      falling_edge: DISABLE
    update_interval: 15s
  - platform: bmp280
    temperature:
      name: "PS4 Temperature"
      oversampling: 16x
    pressure:
      name: "PS4 Pressure"
    address: 0x76
    update_interval: 20s
output:
  - platform: esp8266_pwm
    pin: D3
    frequency: 10000 Hz
fan:
  - platform: speed
    output: fanhub_pwm
Looks like you used pins D3 and D4 which is a poor choice as they have limitations. :no_entry:
Try to use D5, D6 or D7 instead as it might just works :raised_hands:
