I am having a little challenge controlling 12v PWM fans with ESPHome.
Everything works as expected, fan control etc, and my fans shut down when less than 5% on PWM.
Problem I have is, on boot, fans start at (guessing from sound) 100% and my ESP32 never becomes available in HA. If i disconnect power to the fans, and allow the ESP32 to boot before connecting power to the fans, all is good.
I have this issue with the usual ESP32 boards i buy from amazon (3 pack ESP32 ESP-32S Development Board 2.4 GHz Dual Core WLAN WiFi + Bluetooth 2-In-1 Microcontroller ESP-WROOM-32 Chip CP2102 for Arduino (3PCS): Amazon.co.uk: Business, Industry & Science), but i also tested with an ESP32 C6, which DOES NOT suffer the same issue.
I know i could add a relay or mosfet etc to manage power to the fans, but I was hoping someone might be able to point me to a config fix.
It feels like starvation of power to the board stopping it booting properly, but given this happens with one 12v fan through a 3amp 12v DC plug with a buck down to 5v powering the ESP32, i cant really see how it would be starved. I will try and post my config when i figure out how.
esphome:
friendly_name: Enclosure Extractor Fan
esp32:
board: esp32dev
framework:
type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxx"
ota:
- platform: esphome
password: "xxx"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Enclosure-Extractor-Fan"
password: "UFj1UGgtvkeH"
# Define the PWM output for the fan
output:
- platform: ledc
pin: GPIO12
frequency: 25000 Hz
- platform: ledc
pin: GPIO26
frequency: 25000 Hz
# Define the fan component using the PWM output
fan:
- platform: speed
output: pwm_output
- platform: speed
output: pwm_output2
name: "PWM Fan 2"
# RPM
- platform: pulse_counter
pin: GPIO14
unit_of_measurement: "RPM"
filters:
- multiply: 0.5 # Adjust based on your fan's pulses per revolution
pin: GPIO27
filters:
Thanks in advance.
