Pylontech US5000 communication problem
Hello
I try to conntact my new Pylontech US5000 to HomeAssist.
I use a ESP32 or a Vemos D1mini. With a Max3232 and the Console Port at the Batterie
But I dont get values for the Battery.
I try the same with some Older Batterie (Pylontech US2000C Software:2.6)
there it works.
I think my Battery is to new for this software.
I try it to connect with Pylontech Batteryview Version3.0.33 and 3.0.29:
the connect to the single battery works here i get Values
if I want to connect all Units over the master Battery it doesnt work.
I think the battery send to much value.
Can someone help me?
here my code in ESP-Home
captive_portal:
uart:
  tx_pin: GPIO12
  rx_pin: GPIO13
  baud_rate: 115200 # baudrate for pylontech uart
  debug:
      direction: BOTH
      dummy_receiver: false
      after:
        delimiter: "\n"
      sequence:
        - lambda: UARTDebug::log_string(direction, bytes);
# Example configuration entry
pylontech:
  update_interval: 10s
  - platform: pylontech
    battery: 1
    voltage:
      name: "Battery 1 Voltage"
    current:
      name: "Battery 1 Current"
    coulomb:
      name: "Battery 1 Resistance"
    temperature:
      name: "Battery 1 Temperature"
    battery: 2
    voltage:
      name: "Battery 2 Voltage"
    current:
      name: "Battery 2 Current"
    coulomb:
      name: "Battery 2 Resistance"
    temperature:
      name: "Battery 2 Temperature"
and here the log from the failed connection with Batterie view:
没有机种特定的升级配置文件,使用默认升级配置文件
Record Begin:
Record Time: 25-04-02 21:29:07:553
Exception: System.Exception: the column of  'Tlow.Id ' of pwr commandline is not contained in config file,
please configurate file:@\Configs\RegoutConfig.xml
   at BatteryView.Utilities.PwrCellInfo.ConfigPwrsDataReg(String buffer) in D:\Work\界面\低压\问题\BatteryView_us2000b_series_3.0.32\BatteryView\Utilities\DataShowSave.cs:line 1967
   at Pylon.Battery.BatManageUnit.InitializeListRegedPwrData(String strInfo) in D:\Work\界面\低压\问题\BatteryView_us2000b_series_3.0.32\BatteryView\BatManageUnit.cs:line 2202
   at BatteryView.PylonPort.PylonSerialPort.SerialSendCommand(String strcmd, ResponsePattern responsePattern, CmdFinishHandle cmdfinishcallback, Int32 ntimeout, Int32 ntryCount, Int32 resolveCount) in D:\Work\界面\低压\问题\BatteryView_us2000b_series_3.0.32\BatteryView\PylonPort\PylonSerialPort.cs:line 625
Description:
PylonException:
Date/Time: 25-04-02 21:29:07:553
Exception Description: fail to resolve the buffer:
of the 0trys
Record End
Record Begin:
Description:
PylonSerailPortException:
Command: pwr
Residual: null
Response: pwr
Power Volt   Curr   Tempr  Tlow   Tlow.Id  Thigh  Thigh.Id Vlow   Vlow.Id  Vhigh  Vhigh.Id Base.St  Volt.St  Curr.St  Temp.St  Coulomb  Time                 B.V.St   B.T.St  MosTempr M.T.St   SysAlarm.St
1     49679  -3160  16500  14800  12       15900  0        3311   13       3312   0        Dischg   Normal   Normal   Normal   92%      2025-04-03 03:27:20  Normal   Normal  16200    Normal   Normal
2     49690  -2377  18000  15500  10       15800  5        3312   0        3313   2        Dischg   Normal   Normal   Normal   88%      2025-04-03 03:27:17  Normal   Normal  16800    Normal   Normal
3     49682  -2386  18000  15700  10       15800  0        3311   5        3313   3        Dischg   Normal   Normal   Normal   86%      2025-04-03 03:27:17  Normal   Normal  16900    Normal   Normal
4     -      -      -      -      -      -      -      Absent   -        -        -        -        -                    -        -
5     -      -      -      -      -      -      -      Absent   -        -        -        -        -                    -        -
6     -      -      -      -      -      -      -      Absent   -        -        -        -        -                    -        -
7     -      -      -      -      -      -      -      Absent   -        -        -        -        -                    -        -
8     -      -      -      -      -      -      -      Absent   -        -        -        -        -                    -        -
9     -      -      -      -      -      -      -      Absent   -        -        -        -        -                    -        -
10    -      -      -      -      -      -      -      Absent   -        -        -        -        -                    -        -
11    -      -      -      -      -      -      -      Absent   -        -        -        -        -                    -        -
12    -      -      -      -      -      -      -      Absent   -        -        -        -        -                    -        -
13    -      -      -      -      -      -      -      Absent   -        -        -        -        -                    -        -
14    -      -      -      -      -      -      -      Absent   -        -        -        -        -                    -        -
15    -      -      -      -      -      -      -      Absent   -        -        -        -        -                    -        -
16    -      -      -      -      -      -      -      Absent   -        -        -        -        -                    -        -
Command completed successfully
pylon_debug>
Record End
