Pyscript: How to trigger a script on change of a climate entity?
I am using pyscript with @state_trigger.
This works perfectly fine for “simple” entities like numbers.
But how can I use @state_trigger with a climate entity?
I tried this:
@state_trigger("climate.panasonic_heat_pump_main_z1_temp_2")
def state_trig_func(**kwargs):
    log.info(f"state_trig_func called with climate entity: kwargs={kwargs}")
# and this:
@state_trigger("climate.panasonic_heat_pump_main_z1_temp_2.current_temperature")
    log.info(f"state_trig_func called with current temperature: kwargs={kwargs}")
But my script is never been called, although the main state of the entity (heat / off) and the current_temperature changed.
I am using HA 2025.9.1 and pyscript 1.6.4
Please help!
Thx, Klaus
I just realised that probably I would have to react on the service call changing the temperature, not on the change of the attribute
Nobody has an idea?
