Pyscript: Running HA core code that is not part of a service
Hopefully I’m using the correct terms here… I want to run a delete_event script in Pyscript, but the code is not yet implemented in HA as a service call. The calendar documentation is here.
To do this, I went into the example code on the page, and I attempted to include it in my pyscripts .py file. The code, rudimentary as it is, is below:
from homeassistant.core import HomeAssistant
from homeassistant.components.calendar import CalendarEntity
from homeassistant.helpers.entity import Entity, EntityDescription
Entity = "calendar.test"
class CalendarEntity(Entity):
    async def async_delete_event(
        self,
        uid: str,
        recurrence_id: str | None = None,
        recurrence_range: str | None = None,
        ) -> None:
        """Delete an event on the calendar."""
# Define a coroutine to call the async method
async def main():
    await CalendarEntity(Entity).async_delete_event(uid="XXXXXXX")
# Run the coroutine in the event loop
asyncio.run(main())
Conceptually, is this even possible? Can I use example code, bring in the same imports as were on the HA Core Github page, and then run it? When I do so currently, I get the very unhelpful “Exception” error in the logs, pointing to line 24, which is this:
I doubt that I’m being very clear, but I’m happy to clarify if it’s helpful.
