I recently upgrade python version to 3.7.3 and then asuswrte device_tracker doesn’t work any more
I found below errors in HA log. Do we have a solution or workaround available?
File “/srv/homeassistant/lib/python3.7/site-packages/homeassistant/setup.py”, line 153, in _async_setup_component hass, processed_config)
File “/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/asuswrt/init.py”, line 45, in async_setup from aioasuswrt.asuswrt import AsusWrt
File “/srv/homeassistant/lib/python3.7/site-packages/aioasuswrt/asuswrt.py”, line 9, in from aioasuswrt.connection import SshConnection, TelnetConnection
File “/srv/homeassistant/lib/python3.7/site-packages/aioasuswrt/connection.py”, line 6, in
import asyncssh
File “/srv/homeassistant/lib/python3.7/site-packages/asyncssh/init.py”, line 31, in
from .agent import SSHAgentClient, SSHAgentKeyPair, connect_agent
File “/srv/homeassistant/lib/python3.7/site-packages/asyncssh/agent.py”, line 35, in
from .public_key import SSHKeyPair, load_default_keypairs
File “/srv/homeassistant/lib/python3.7/site-packages/asyncssh/public_key.py”, line 43, in
from .encryption import get_encryption_params, get_encryption
File “/srv/homeassistant/lib/python3.7/site-packages/asyncssh/encryption.py”, line 23, in
from .crypto import BasicCipher, GCMCipher, ChachaCipher, get_cipher_params
File “/srv/homeassistant/lib/python3.7/site-packages/asyncssh/crypto/init.py”, line 27, in
from .ec import ECDSAPrivateKey, ECDSAPublicKey, ECDH
File “/srv/homeassistant/lib/python3.7/site-packages/asyncssh/crypto/ec.py”, line 24, in
from cryptography.hazmat.backends.openssl import backend
File “/srv/homeassistant/lib/python3.7/site-packages/cryptography/hazmat/backends/openssl/init.py”, line 7, in
from cryptography.hazmat.backends.openssl.backend import backend
File “/srv/homeassistant/lib/python3.7/site-packages/cryptography/hazmat/backends/openssl/backend.py”, line 74, in
from cryptography.hazmat.bindings.openssl import binding
File “/srv/homeassistant/lib/python3.7/site-packages/cryptography/hazmat/bindings/openssl/binding.py”, line 15, in
from cryptography.hazmat.bindings._openssl import ffi, lib
ImportError: /usr/lib/arm-linux-gnueabihf/libssl.so.1.1: version `OPENSSL_1_1_1’ not found (required by /srv/homeassistant/lib/python3.7/site-packages/cryptography/hazmat/bindings/_openssl.abi3.so)
2019-07-28 19:37:45 ERROR (MainThread) [homeassistant.setup] Error during setup of component cloud
File “/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/cloud/init.py”, line 142, in async_setup from hass_nabucasa import Cloud
File “/srv/homeassistant/lib/python3.7/site-packages/hass_nabucasa/init.py”, line 16, in
from .remote import RemoteUI
File “/srv/homeassistant/lib/python3.7/site-packages/hass_nabucasa/remote.py”, line 16, in
from .acme import AcmeClientError, AcmeHandler
File “/srv/homeassistant/lib/python3.7/site-packages/hass_nabucasa/acme.py”, line 9, in
import OpenSSL
File “/srv/homeassistant/lib/python3.7/site-packages/OpenSSL/init.py”, line 8, in
from OpenSSL import crypto, SSL
File “/srv/homeassistant/lib/python3.7/site-packages/OpenSSL/crypto.py”, line 16, in
from OpenSSL._util import (
File “/srv/homeassistant/lib/python3.7/site-packages/OpenSSL/_util.py”, line 6, in
from cryptography.hazmat.bindings.openssl.binding import Binding
2019-07-28 19:37:46 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform asuswrt.device_tracker: Unable to set up component.
2019-07-28 19:37:47 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: cloud
2019-07-28 19:37:47 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
