Hello there,
I’m into new territory here, I got a new vacuum and I see that I can update the library by running pip install, I’ve done that through the terminal in studio code, and all came back clean. Yet I see no change in the plugin, my vacuum is still not visible.
Ecovacs is the plugin in question, vacuum is an x11 which it has been updated for.
I’ve deleted my previous setup in the plugin, restarted, and still nothing.
Just checking that I’ve done this right and I don’t need to do anything after running the install command.
Thank you for the reply. I already had the integration installed and functional. Yet the new vacuum didn’t report in. So it seemed that if I ran the install I’d get the latest device library.
So I just have to wait for the integration to be updated as opposed to what I did earlier?
