WHat is the current Python version in the latest version of HA?
Mine says Python 3.12.9
I’m confused because I have some errors in the log pointing to /usr/local/lib/python3.13/site-packages
I run HAOS 15 and Core 2025.3.4
How to troubleshoot this,
THanks for any help you might give me.
WallyR
(Wally)
March 24, 2025, 11:09am
2
3.13.2
You might not be running the command in the homeassistant container or you are running in a non-docker or non-HAOS installation where you need to install it yourself.
I use:
Core: 2025.3.4
Supervisor: 2025.03.3
Operating System: 15.0
Frontend: 20250306.0
And I run the command from the Advanced SSH & Web Terminal add-on
WallyR
(Wally)
March 24, 2025, 4:30pm
4
That is another docker container. It could just as well have been a completely different hardware server.
@WallyR Do you know how to access /usr/local/lib/python3.13/site-packages to check which files are in there?
WallyR
(Wally)
March 28, 2025, 4:06pm
7
I use the console directly, so either a monitor and keyboard connected to the HA server or if you run a supervisor then the console page in that.
At the HA prompt type login to get to a normal linux shell.
Now use the Docker commands to run commands in the containers, like
docker container exec homeassistant ls ,/bin
Hi Wally,
Sorry for my ignorence but I need more guidance here. Do you have a step by step example
Hi Wally,
Thank you very much.
You saved me, and now my problem is solved with the custom integration.
