Python script as shell command - import problem
I run HA (v0.100.2 right now) successfully in Docker for ARM64.
I’d like to run my python script (that reads data via RS485) which has some imports:
import minimalmodbus
import paho.mqtt.client as mqtt
import paho.mqtt.publish as pub
So when I call it from container I’m getting import errors like that:
# python3 /config/sdm630/sdm630_to_mqtt.py
  File "/config/sdm630/sdm630_to_mqtt.py", line 2, in <module>
ModuleNotFoundError: No module named 'minimalmodbus'
How to deal with it? I can install these modules manually but it’s temporary solution until I upgrade HA - container will be recreated then and modules will gone away…
You can’t import in a python script. The environment is limited. I suggest moving to appdeamon or make a custom component.
I’m aware of this limitation and that’s why I use shell_command component.
Ah ok, then you need to fork the HA container, add your files and upgrade from that forked container.
Or move to hassbian in a venv and never deal with this.
