Python script suddenly stop working
I am on latest HA 0.92.2 and HASSOS 2.11.
I found this errors:
2019-05-04 12:30:18 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/input_number/.translations/sl.json
2019-05-04 12:30:18 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/onboarding/.translations/sl.json
2019-05-04 12:30:18 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/broadlink/.translations/switch.sl.json
2019-05-04 12:30:19 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/history/.translations/sl.json
2019-05-04 12:30:19 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/conversation/.translations/sl.json
2019-05-04 12:30:19 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/recorder/.translations/sl.json
2019-05-04 12:30:19 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/api/.translations/sl.json
2019-05-04 12:30:19 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/http/.translations/sl.json
2019-05-04 12:30:19 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/python_script/.translations/sl.json
2019-05-04 12:30:19 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/group/.translations/sl.json
2019-05-04 12:30:19 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/system_log/.translations/sl.json
2019-05-04 12:30:19 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/logbook/.translations/sl.json
2019-05-04 12:30:19 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/discovery/.translations/sl.json
2019-05-04 12:30:19 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/hassio/.translations/sl.json
2019-05-04 12:30:19 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/lovelace/.translations/sl.json
2019-05-04 12:30:19 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/map/.translations/sl.json
2019-05-04 12:30:19 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/automation/.translations/sl.json
2019-05-04 12:30:19 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/persistent_notification/.translations/sl.json
2019-05-04 12:30:19 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/logi_circle/.translations/sl.json
2019-05-04 12:30:19 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/updater/.translations/sl.json
2019-05-04 12:30:19 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/tts/.translations/sl.json
2019-05-04 12:30:20 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/panel_custom/.translations/sl.json
2019-05-04 12:30:20 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/webhook/.translations/sl.json
2019-05-04 12:30:20 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/frontend/.translations/sl.json
2019-05-04 12:30:20 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/template/.translations/switch.sl.json
2019-05-04 12:30:20 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/sun/.translations/sl.json
2019-05-04 12:30:20 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/switch/.translations/sl.json
2019-05-04 12:30:20 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/config/.translations/sl.json
2019-05-04 12:30:20 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/sensor/.translations/sl.json
2019-05-04 12:30:20 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/homeassistant/.translations/sl.json
2019-05-04 12:30:20 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/light/.translations/sl.json
2019-05-04 12:30:20 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/logger/.translations/sl.json
2019-05-04 12:30:20 DEBUG (SyncWorker_7) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/websocket_api/.translations/sl.json
2019-05-04 12:30:20 DEBUG (SyncWorker_6) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/input_number/.translations/en.json
2019-05-04 12:30:20 DEBUG (SyncWorker_6) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/onboarding/.translations/en.json
2019-05-04 12:30:20 DEBUG (SyncWorker_6) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/broadlink/.translations/switch.en.json
2019-05-04 12:30:20 DEBUG (SyncWorker_6) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/history/.translations/en.json
2019-05-04 12:30:20 DEBUG (SyncWorker_6) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/conversation/.translations/en.json
2019-05-04 12:30:20 DEBUG (SyncWorker_6) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/recorder/.translations/en.json
2019-05-04 12:30:20 DEBUG (SyncWorker_6) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/api/.translations/en.json
2019-05-04 12:30:20 DEBUG (SyncWorker_6) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/http/.translations/en.json
2019-05-04 12:30:20 DEBUG (SyncWorker_6) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/python_script/.translations/en.json
2019-05-04 12:30:20 DEBUG (SyncWorker_6) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/group/.translations/en.json
2019-05-04 12:30:20 DEBUG (SyncWorker_6) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/system_log/.translations/en.json
2019-05-04 12:30:20 DEBUG (SyncWorker_6) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/logbook/.translations/en.json
2019-05-04 12:30:20 DEBUG (SyncWorker_6) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/discovery/.translations/en.json
2019-05-04 12:30:20 DEBUG (SyncWorker_6) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/hassio/.translations/en.json
2019-05-04 12:30:20 DEBUG (SyncWorker_6) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/lovelace/.translations/en.json
2019-05-04 12:30:20 DEBUG (SyncWorker_6) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/map/.translations/en.json
2019-05-04 12:30:20 DEBUG (SyncWorker_6) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/automation/.translations/en.json
2019-05-04 12:30:20 DEBUG (SyncWorker_6) [homeassistant.util.json] JSON file not found: /usr/local/lib/python3.7/site-packages/homeassistant/components/persistent_notification/.translations/en.json
