Suddenly two devices stopped working after more than a year. The sensors return unknown value. I tried to reset, recharge, nothing to do. Do you think it could be a software problem or do I have to buy two new Pzem?
esphome:
friendly_name: Energy Monitor
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
level: debug
baud_rate: 0
# Enable Home Assistant API
api:
encryption:
key: "xxxxx"
ota:
platform: esphome
password: "xxxx"
wifi:
ssid: !secret wifi_ssid
fast_connect: True
#manual_ip:
#static_ip: 192.168.1.79
#gateway: 192.168.1.1
#subnet: 255.255.255.0
#dns1: 192.168.1.1
#dns2: 8.8.4.4
ap:
ssid: "Energy-Monitor Fallback Hotspot"
password: "xxxxx"
time:
- platform: sntp
timezone: Europe/Rome
binary_sensor:
- platform: status
name: EspHome Node Status
text_sensor:
- platform: version
hide_timestamp: True
- platform: wifi_info
ip_address:
name: "Node IP Address"
captive_portal:
uart:
- id: ubus
rx_pin: GPIO1
tx_pin: GPIO3
baud_rate: 9600
stop_bits: 1
modbus:
- id: mbus
uart_id: ubus
button:
- platform: restart
- platform: wifi_signal
update_interval: 30s
- platform: pzemac
modbus_id: mbus
address: 1
current:
name: "Clima salone Corrente"
voltage:
name: "Clima salone Tensione"
energy:
name: "Clima salone Energia"
power:
name: "Clima salone potenza"
update_interval: never
- platform: pzemac
modbus_id: mbus
address: 2
current:
name: "Corrente Pompa pozzo"
voltage:
name: "Tensione Pompa pozzo"
energy:
name: "Energia Pompa pozzo"
power:
name: "Potenza Pompa pozzo"
frequency:
name: "Frequenza Pompa pozzo"
power_factor:
name: "Power Factor Pompa pozzo"
- platform: pzemac
modbus_id: mbus
address: 3
current:
name: "Clima camera corrente"
voltage:
name: "Clima camera tensione"
energy:
name: "Clima camera energia"
power:
name: "Clima camera potenza"
interval:
- interval: 3s
then:
- delay: 150ms
- lambda: "id(pzemac_1).update();"
- delay: 150ms
- lambda: "id(pzemac_2).update();"
- delay: 150ms
- lambda: "id(pzemac_3).update();"
switch:
- platform: uart
uart_id: ubus
name: pzem reset 1
data: [0x01, 0x42, 0x80, 0x11]
- platform: uart
uart_id: ubus
name: pzem reset 2
data: [0x02, 0x42, 0x80, 0xE1]
- platform: uart
uart_id: ubus
name: pzem reset 3
data: [0x03, 0x42, 0x81, 0x71]
