PZEM 004T V4.0 - Esphome Not able to read simultaneously from all 3 PZEM's
When connected together I’am not able to read from PZEM’s
Have assigned unique ID’s for all 3 PZEMs
Individually, I’m able to read them in their respective IDs
But when connected altogether, they are not working
One observation from PZEM LED status is that all PZEMs transmit together, same with receiving too
Hardware Setup
Wemos D1 Mini
PZEMs are directly connected to TX-RX (parallel connection with no pullup resistor or diode)
Any support will be invaluable :slight_smile:
Full code below
substitutions:
  devicename: 3phase-power-monitor
  friendly_name: Power Monitor
esphome:
  friendly_name: ${friendly_name}
  name_add_mac_suffix: false
  project:
    version: "1.0"
esp8266:
  board: esp01_1m
logger:
  baud_rate: 0        # free UART for PZEM
  level: DEBUG        # change to INFO later
wifi:
  ssid: !secret wifi_id
  password: !secret wifi_pw
  ap:
    ssid: $devicename
    password: "1122334455"
ota:
  - platform: esphome
api:
web_server:
  port: 80
  version: 3
dashboard_import:
  package_import_url: github://esphome/example-configs/esphome-web/esp8266.yaml@main
  import_full_config: true
time:
  - platform: homeassistant
uart:
  tx_pin: GPIO1
  rx_pin: GPIO3
  baud_rate: 9600
  stop_bits: 1
  parity: NONE
# Increased modbus timing to prevent bus contention
modbus:
  send_wait_time: 2000ms  # 2 seconds between requests
binary_sensor:
  - platform: status
text_sensor:
  - platform: wifi_info
    ip_address:
      name: "${devicename} IP Address"
    ssid:
      name: "${devicename} Connected SSID"
    mac_address:
      name: "${devicename} MAC Address"
  - platform: wifi_signal
    name: "${devicename} WiFi Signal"
    update_interval: 60s
  - platform: uptime
  # --------- PHASE L1 ----------
  - platform: pzemac
    address: 1
    modbus_id: mod_bus_pzem
    update_interval: 90s  # Long interval, controlled by automation
    current:
    voltage:
    energy:
      device_class: energy
      state_class: total_increasing
      unit_of_measurement: "Wh"
    power:
      device_class: power
      state_class: measurement
    frequency:
    power_factor:
      name: "Power Factor L1"
  # --------- PHASE L2 ----------
  - platform: pzemac
    address: 2
    current:
    voltage:
    energy:
    power:
      device_class: power
    frequency:
    power_factor:
      name: "Power Factor L2"
  # --------- PHASE L3 ----------
  - platform: pzemac
    address: 3
    current:
    voltage:
    energy:
    power:
      device_class: power
    frequency:
    power_factor:
      name: "Power Factor L3"
  # --------- DAILY ENERGY PER PHASE (kWh) ----------
  - platform: total_daily_energy
    name: "Energy L1 Daily"
    power_id: power_l1
    unit_of_measurement: kWh
    accuracy_decimals: 3
    filters:
      - multiply: 0.001
    name: "Energy L2 Daily"
    power_id: power_l2
    filters:
      - multiply: 0.001
    name: "Energy L3 Daily"
    power_id: power_l3
    filters:
      - multiply: 0.001
  # --------- CALCULATED TOTAL SENSORS ----------
    device_class: power
    unit_of_measurement: W
    accuracy_decimals: 1
    update_interval: 30s
    lambda: |-
      float p1 = id(power_l1).state;
      float p2 = id(power_l2).state;
      float p3 = id(power_l3).state;
      if (isnan(p1) || isnan(p2) || isnan(p3)) {
        return NAN;
      return p1 + p2 + p3;
    lambda: |-
      float e1 = id(energy_l1).state;
      float e2 = id(energy_l2).state;
      float e3 = id(energy_l3).state;
      if (isnan(e1) || isnan(e2) || isnan(e3)) {
        return NAN;
      float total_wh = e1 + e2 + e3;
      return total_wh * 0.001;
    name: "Total Daily Energy"
    lambda: |-
      float e1 = id(energy_l1_daily).state;
      float e2 = id(energy_l2_daily).state;
      float e3 = id(energy_l3_daily).state;
        return NAN;
      return e1 + e2 + e3;
button:
  - platform: restart
    name: "Reset Energy L1"
    on_press:
      then:
        - pzemac.reset_energy: pzemac1
    name: "Reset Energy L2"
    on_press:
      then:
        - pzemac.reset_energy: pzemac2
    name: "Reset Energy L3"
    on_press:
      then:
        - pzemac.reset_energy: pzemac3
# SEQUENTIAL POLLING - Critical fix for bus contention
# Poll Phase 1 every 30 seconds
interval:
  - interval: 30s
    then:
      - component.update: pzemac1
# Poll Phase 2 every 30 seconds, but offset by 10 seconds
  - interval: 10s
    then:
      - delay: 10s
      - component.update: pzemac2
# Poll Phase 3 every 30 seconds, but offset by 20 seconds
  - interval: 20s
    then:
      - delay: 20s
      - component.update: pzemac3
Normal uart line is not a bus like rs485 is.
I was able to solve this by adding a 1N5819 diode to each TX line.
Even 2x PZEM-004T 4.0 had this problem.
The issue is that when there are two or more devices, the signal cannot pull the level down close to GND.
Here is 1x 4.0,2x4.0,2x4.0 With 1N5819 Fix.
yup! Thanks for this :slight_smile:
Hi everyone,
I’m facing a very similar situation, but unfortunately the diode solution didn’t work in my case.
Behavior
  • Each PZEM works correctly when connected individually
My setup
  • ESP32-C3 SuperMini, powered at 5V
  • 3x PZEM-004T V4, powered at 5V
  • Common GND for all devices
  • UART lines connected in parallel
  • Each PZEM has a unique address
  • Baud rate: 9600
  • Tested using GPIO21 (TX) and GPIO20 (RX)
Power supply:
  • 110V AC → HLK-10M (5V DC)
  • +5V and GND distributed to:
    • ESP32-C3
    • All PZEM modules
Your diodes are wrong way, how could they ever pull the line low…
Thanks! You were right — the diodes were reversed. After flipping them, everything works correctly now.
If someone doesn’t want to use a diode. The other way will be to use RS485 modules.
I am unsure on self promotion rules, but I can share a video i made on that topic.
Hi. Are the diodes shown in the diagram are already corrected or do I have to reverse the polarity still? Could you please let me know?
No, connect it the other way
Please do :slight_smile:
