PZEM-6L24 via Modbus integration
As I couldn’t find anywhere a working example on how to configure Paecefair PZEM-6L24 with Modbus integration and an network - Modbus gateway I’m sharing what I have been able to achieve here. A bit frustrating at first as seems that the device uses not so obvious way of reporting data via Modbus. I’m using PUSR USR-DR164 wifi gateway.
Here is my config of the serial port on the gateway:
And here fully working Modbus integration config. Some of it I was only able to figure out using Gemini (e.g. the custom data types, which didn’t work with any of the standard ones).
    - name: "pzem_meter"
      type: tcp
      host: 10.144.30.105 # Replace with your adapter's IP
      port: 502
      delay: 1
      timeout: 5
      byte_order: little
      word_order: little
      sensors:
        - name: "PZEM A Voltage"
          unique_id: pzem_a_voltage
          address: 0
          slave: 1
          input_type: input
          unit_of_measurement: V
          scale: 0.1
          precision: 1
          data_type: uint16
          swap: byte
        - name: "PZEM B Voltage"
          unique_id: pzem_b_voltage
          address: 1
          slave: 1
          input_type: input
          scale: 0.1
          precision: 1
          data_type: uint16
          swap: byte
        - name: "PZEM C Voltage"
          unique_id: pzem_c_voltage
          address: 2
          slave: 1
          input_type: input
          scale: 0.1
          precision: 1
          data_type: uint16
          swap: byte
        # --- CURRENT ---
        - name: "PZEM A Current"
          unique_id: pzem_a_current
          address: 3
          slave: 1
          input_type: input
          unit_of_measurement: A
          scale: 0.01
          precision: 2
          data_type: uint16
          swap: byte
        - name: "PZEM B Current"
          unique_id: pzem_b_current
          address: 4
          slave: 1
          input_type: input
          scale: 0.01
          precision: 2
          data_type: uint16
          swap: byte
        - name: "PZEM C Current"
          unique_id: pzem_c_current
          address: 5
          slave: 1
          input_type: input
          scale: 0.01
          precision: 2
          data_type: uint16
          swap: byte
        # --- ACTIVE POWER PER PHASE ---
        # Phase A: Registers 14 and 15 (0x000E and 0x000F)
        - name: "PZEM A Active Power"
          unique_id: pzem_a_active_power
          address: 14
          slave: 1
          input_type: input
          unit_of_measurement: W
          scale: 0.1
          precision: 1
          device_class: power
          state_class: measurement
          data_type: custom
          structure: "<i"
          count: 2
          # swap: word
        # Phase B: Registers 16 and 17 (0x0010 and 0x0011)
        - name: "PZEM B Active Power"
          unique_id: pzem_b_active_power
          address: 16
          slave: 1
          input_type: input
          scale: 0.1
          precision: 1
          device_class: power
          data_type: custom
          structure: "<i"
          count: 2
        # Phase C: Registers 18 and 19 (0x0012 and 0x0013)
        - name: "PZEM C Active Power"
          unique_id: pzem_c_active_power
          address: 18
          slave: 1
          input_type: input
          scale: 0.1
          precision: 1
          device_class: power
          data_type: custom
          structure: "<i"
          count: 2
        # --- ACTIVE ENERGY PER PHASE ---
        # Phase A: Registers 40 and 41 (0x0028 and 0x0029)
        - name: "PZEM A Active Energy"
          unique_id: pzem_a_active_energy
          address: 40
          slave: 1
          input_type: input
          unit_of_measurement: kWh
          scale: 0.1
          precision: 3
          data_type: custom
          structure: "<I" # Uppercase 'I' for unsigned 32-bit int (energy is not negative)
          count: 2
          device_class: energy
          state_class: total_increasing
        # Phase B: Registers 42 and 43 (0x002A and 0x002B)
        - name: "PZEM B Active Energy"
          unique_id: pzem_b_active_energy
          address: 42
          slave: 1
          input_type: input
          scale: 0.1
          precision: 3
          data_type: custom
          structure: "<I"
          count: 2
        # Phase C: Registers 44 and 45 (0x002C and 0x002D)
        - name: "PZEM C Active Energy"
          unique_id: pzem_c_active_energy
          address: 44
          slave: 1
          input_type: input
          scale: 0.1
          precision: 3
          data_type: custom
          structure: "<I"
          count: 2
        # --- FREQUENCY ---
        - name: "PZEM Frequency"
          unique_id: pzem_frequency
          address: 6
          slave: 1
          input_type: input
          device_class: frequency
          unit_of_measurement: Hz
          scale: 0.01
          precision: 2
          data_type: int16
          swap: byte
        # --- COMBINED ACTIVE POWER ---
        # Registers 0x0020 (Low) and 0x0021 (High) form a 32-bit value
        - name: "PZEM Total Active Power"
          unique_id: pzem_total_active_power
          address: 32 # 0x0020 in decimal
          slave: 1
          input_type: input
          device_class: power
          scale: 0.1
          precision: 1
          data_type: custom
          structure: "<i"
          count: 2
        # --- COMBINED ACTIVE ENERGY ---
        # Registers 0x003A (Low) and 0x003B (High)
        - name: "PZEM Total Energy"
          unique_id: pzem_total_energy
          address: 58 # 0x003A in decimal
          slave: 1
          input_type: input
          scale: 0.1
          precision: 1
          data_type: custom
          structure: "<I" # Capital 'I' for unsigned int 32-bit (energy is not negative)
          count: 2
I’m using it for 3 independent single phase circuits so the totals are not that interesting to me but they seem to show correct values.
There are more datapoints available in the documentation but I believe above should cover all the rest of data types that are exposed by the power meter.
