I have looked at a previous post about the Buva Q-stream. I have gotten the Q-stream Evolution. The board of which is completely different. There is a modbus for 12-24 volt. I do not know if I should use the klik aan klik uit option or can use the cubino. I think the cubino is underpowered for this. But I could be wrong.
i’m also strugeling with controlling the Q-stream Evolution. I want to regluate the Q-stream with an ESP or another wifi module. At the moment it goes only on when there is moisture in the air afte a shower.
has somone build a solustion for the new type Q-stream evolution?
I know this is an old topic, but I’m wondering if by now anyone has had any luck adding the non-10v Q Stream Evolution (the above pcbs version 6 or 7) to Home Assistant? Maybe using the Modbus connector?
I had ordered an extra wired (modbus) control panel in hopes of intercepting the modbus commands and reverse engineering the communication so I could send the same commands from an ESP32 or whatever.
I was able to intercept something, but I realised I know way to little about it (modbus especially) to really make any sense of it
if you have the buva q-stream with wifi, you can control it with a simple python script. here’s the interface:
Get the IP-address for the device, the mac address is the prefix after the word "QStream"in the app (for example: QStream 807A4C7BCEE7)
best to set the ip-fixed of fixed by dhcp.
# the structure from the q-stream
# TIMER INACTIVE/ACTIVE [0] [1]
# SCHEDULE/{val} OFF/MIN [2] [3]
# Qanalog 0% [4] [5]
# Qset 20% [6] [7]
# Qactual 20% [8] [9]
# DEMAND CONTROL ON [10] [11] [12]
# DAY VALVE CLOSED [13] [14] [15]
the http interface returns a string with all its values. (get)
in browser : http://<ip-address>/Status
result :
Value: "TIMER INACTIVE SCHEDULE OFF Qanalog 0% Qset 20% Qactual 20% DEMAND CONTROL ON DAY VALVE CLOSED"
data = { "Value": "TIMER 3 MIN 70% DEMAND CONTROL OFF DAY"}
headers = {'Content-type': 'application/json', 'accept-encoding':'gzip' }
r = requests.post("http://192.168.0.100/Timer", data=json.dumps(data), headers=headers)
maybe someone can make a nice package or python-code for this.
If I send a control signal of 0-10 volts to the blue-yellow control cables, I should be able to control the motor.
I was thinking of using a Qubino ZMNHVD1 Flush 0-10V Dimmer Z-Wave, where I could possibly use the signal from the circuit board as input to ensure that the humidity sensor still works
