QT-OpenZwave Aeotec Zstickgen5 with range extender 6 door sensor out of range
Hello, I have this setup running:
The new OpenZwave integration. Integrated and working “well” (well, acceptable for testing).
I have recently added 2 doorsensors. Included succesfully and working. But.
I have the Aeotec Z-stick in my hass. Then I have succesfully included and can see working aeotec range extender about 15m from the zstick.
now when I move the doorsensor closer to the range extender it does not send any updates anymore… If I walk back towards the zstick it picks it up again…
Where do I need to start troubleshooting? I am used to zwave and that routing will happen if the controller is not near. I also tried to heal the network, does not help.
After moving the Sensor to new location, wake up the Sensor manually.
Hi, thank you, yes I did that… Also removing battery and inserting not helping.
Are You sure, that your repeater is in range of the Gateway?
Yes, i was sure… I now tried to wake and that did not do anything. So I moved it a meter and now it’s working… strange thing. thanks for thinking with me!
