Qubino Flush Dimmer No way to set dimmer level
Hi, Newbie here. Running HassOS 3.13 on a Raspberry Pi 4 into which I’ve integrated a (ZWave) Qubino Flush Dimmer ZMNHDDx (qubino.com/products/flush-dimmer). The relevant part of the Overview page looks like
As you can see all the readouts are there with two control switches. The lower switch turns the light on full bright and off. The upper switch turns the light on to it’s preset dimmer position and off.
But where is the Slider widget to control the dimmer position?
Any help greatly appreciated. Cheers
Are you using Lovelace, if so try this
  • type: light
    entity: light.qubino_goap_zmnhdd1_flush_dimmer_level
