Querying HVAC Mode on Nest in automation
I have automations that set the temp at certain times of the day. I want to query the HVAC mode and set it to one temp depending on mode. I want something to the effect: IF HVAC-MODE = heat then set temp to 68. I found some code but it didn’t seem to work. I pasted stuff into the File editor version of the automations, and the code gets stripped out.
Can anyone point me in the right direction to get something like this done?
Thanks in advance…
Hello Pop06095,
Run thru the docs on getting started with the automation editor. If you get stuck, come back with what you have done.
and
The Home Assistant Cookbook - Index.
