I have several local calendars that are working fine. I can query each calendar individually using the following code.
(5 min time is just for testing!!)
- trigger:
platform: time_pattern
minutes: /5
- service: calendar.get_events
entity_id: calendar.recurring_events
start_date_time: "{{ now().strftime('%Y-%m-%d 00:00:00') }}"
end_date_time: "{{ (now() + timedelta(days=5)).strftime('%Y-%m-%d 00:00:00') }}"
response_variable: calendar_events_response
- name: Recurring Events Sensor
unique_id: recurring_events_sensor
state: "{{ calendar_events_response['calendar.recurring_events'].events | count() }}"
attributes:
calendar_events_response: "{{ calendar_events_response['calendar.recurring_events'].events }}"
icon: mdi:calendar
This gets me the following response
calendar.recurring_events:
events:
- start: "2025-05-14"
end: "2025-05-15"
summary: Trash Pick-up
description: Trash Pick-up
- start: "2025-05-18"
end: "2025-05-19"
summary: Recycling Pick-up
description: Recycling Pick-up
All fine and good. Now, in the Actions tab of the Developer Tools I can query multiple calendars at once using
action: calendar.get_events
duration:
hours: 120
minutes: 0
seconds: 0
entity_id:
- calendar.recurring_events
- calendar.local_events_2025
- calendar.school_2025
and getting this response
events:
end: "2025-05-15"
end: "2025-05-19"
calendar.local_events_2025:
events:
- start: "2025-05-16T14:00:00-04:00"
end: "2025-05-16T16:00:00-04:00"
summary: Test Summary
description: Test Description
summary: Test Summary 2
description: Test Description 2
calendar.school_2025:
events: []
Where I need help is with the response, particularly how to get all calendars instead of just one.
>> THIS LINE
state: "{{ calendar_events_response['calendar.recurring_events'].events | count() }"
attributes:
>> AND THIS LINE
icon: mdi:calendar
I have tried
calendar_events_response['calendar.recurring_events','calendar.local_events_2025','calendar.school_2025'].events|count()
calendar_events_response.events|count()
and
calendar_events_response[].events|count()
None work. There must be a solution to this if it can be done in the Developer tab, but I can’t find an answer.
If there’s a better way to get all the calendar data for several upcoming days into a sensor attribute I’m willing to give it a try.
Note: None of the cards out there do exactly what Im trying to accomplish, and as an alternative I know could create 3 separate template sensors. My brain makes me want to stuff it all into one sensor if it’s possible.
